bolt underneath leaking
Colby
Those bolts forward of the drain plug... what do they do? This is the second banshee i have had that has the exact same bolt leaking. What can be done to fix the problem ?
they hold the engine cases together.....
there is a hole above in the middle of the cases, you most likely have something leaking thru there....
what kind of liquid?
Edited by Hilarious
those are holding your cases together. must not have enough yamabond between the cases in that area. is it tranny fluid? might have to split them to fix it properly. Or its gas leaking from your carb and running through the hold thats in the cases and looks like it coming from somewhre else.
