06bluebanshee Posted March 23, 2012 Report Posted March 23, 2012 I got my top end redone and put all back together today. I started it up and it would only run both cylinders on choke. When I shut off the choke it would only run on 1 cylinder!!! Pull choke back out and 2 cylinders fire. Choke off 1 cylinder won't idle without throttle on. HELP!! Am I too lean? Or is my pilot too small? Pilot clogged? .10 over, T6, NOSS head 21cc domes, Vforce 3 reed cages, open air box k&n, 800 feet above sea, stock carbs, 27.5 pilot, 320 mains... What do you guys think??? Quote
Infamous039 Posted March 23, 2012 Report Posted March 23, 2012 Sound like you need to clean the carbs out also take a look at your reeds and make sure none of the petals have cracks. Quote
Overboost Posted March 23, 2012 Report Posted March 23, 2012 SYNC them puppies rev it up, they will catch, thats how you know its sync if you choke it. choke gives more gas in a circuit, so if you sync them, same effect. once it warms up they stay puffing.....carb sync is your issue. if you did, you didnt do it right....had this problem, thats what it was, every time Quote
RadarRacing Posted March 23, 2012 Report Posted March 23, 2012 Also, if you have the carbs in the wrong side the choke circuit is wrong. The carb bowl with the brass bearing looking thing goes in the left cyl. If its not that then make sure the pistons have the windowsfacing the reeds not exhaust. They can be installed backwards. Quote
Jereme6655 Posted March 23, 2012 Report Posted March 23, 2012 it may be something like your pilot could be clogged or it could be that your way too lean on jetting .......i just rebuilt both my carbs and had the same problem as soon as i fired the bike up....blip the throttle a little they'd both fire....let it try to idle it would run on one and then die..... it was because one of my carbs had the idle set too low...happened during cleaning. Quote
06bluebanshee Posted March 23, 2012 Author Report Posted March 23, 2012 Fixed it.... pilot jets were clogged. Ended up putting 30 pilots and 330 mains, Thanks guys! Quote
