Started the banshee and as son as it fired up there was a knock.. would that be from a rod bearing going out? or maybe a broken piston skirt?? or will i just have to tear it apart and check it out.. it had ran perfectly fine the day before.. just loking for some opinions before i begin to tear it down..
I've had bad clutch basket cushions make a knocking sound. The basket smacks back and forth against the gear and makes a knocking sound.
- Jared
i might check that.. cuz i did expierence clutch problems... it seems as if i would pull the clutch and there was no resistance at all.. and the clutch wouldnt work...
Pull your clutch cover and see what is going on in there first. Bad cushions ib the basket can make it knock, or if the snap ring and washer came off the kick idler gear and ran thruogh the primary gears, it can damage a gear tooth and make it knock.
