DirtDiggler69 Posted January 17, 2012 Report Posted January 17, 2012 Has anyone here used those lights from from walmart called " Platinum Burners " on their banshee? I'm doing a budget build , need to get done by Dunefest and need some lights for night riding . I had a set on my blaster and they worked good . The Blasters stator could only run the 20 watt bulbs . They also have 25 watt bulbs , can the stator on the banshee run those ? What is the stock output of the banshee stator? Quote
toomeysgoroom Posted January 17, 2012 Report Posted January 17, 2012 My shee is running 55watt bulbs and they are dimm as hell even when im on the power i wouldnt go over a 45watt Quote
Man-O-Steele Posted January 17, 2012 Report Posted January 17, 2012 Your bulbs are to big run 35w. I had the same problem. Quote
DirtDiggler69 Posted January 17, 2012 Author Report Posted January 17, 2012 So the stock stator can run up to a pair of 35 watt bulbs? That's good , what about the tail light? I was gonna run a small round red light that's maybe 5w total . Quote
Larry's Shee Posted January 17, 2012 Report Posted January 17, 2012 IIRC, it's 70-75 max. Maybe look for a LED clearance light for back. Quote
bansheesandrider Posted January 17, 2012 Report Posted January 17, 2012 The stock bulbs are 35W apiece on either high OR low beam. I am not sure what the tailight draws, but later bike use a 1157 bulb and early bike use a 194 bulb, whish is what is used in a non sealed clearance light. So 5W for the taillight is about right. As long as you don't go over 35W apiece in the headlight and use a reasonable taillight bulb, you will be fine. Quote
SpecialEd 05 Posted February 4, 2012 Report Posted February 4, 2012 Yeah the stock headlight bulbs are 30w/30w hi/low and the tail light is 5w/21w tail/brake. For last riding season I fitted a set of PIAA H6M bulbs to the stock housings. These run at 35w/35w hi/low but because they are a xenon hybrid bulb they are equivalent to 60w/60w halogen. A problem the Banshee has even with the stock bulbs is that when you hit the brakes you lose almost half your lighting because the 21w brake filament robs a lot of power. to overcome this I fitted a BAY15D LED hybrid bulb. The low current draw means that when you hit the brakes at night you don't lose any lighting (unless the engine stalls) The only downside is the LED bulb can be difficult to see during the day. I simply swap out the stock bulb during the day any run the LED at night, it only takes a minute. Another tip for better lighting is to remove the headlight buckets from the housings and remove the grill, then polish the lens with some metal polish. You'll be surprised how much clearer they come up... Quote
