Jackl Posted January 15, 2012 Report Posted January 15, 2012 Hi guys new to the forum, new banshee owner bansee has been great last four or five rides, Today long easy stretch couf couf back fire a couple times, rev it up ran ok ten minutes later couf couf died, buddy behind me said no smoke right side figured fouled plug changed plug fired up still coughs out right side puffing sound wont run right, right side really hot is it in the carb no fuel or what tapped the carb thought maybe stuck float no luck. where do i start?. low compression? cracked piston or carb problem ? dont know. Thanks. Quote
Dicklez Posted January 15, 2012 Report Posted January 15, 2012 Well I would start with a compression check. Even just your finger over the hole to see if you have anything. Make sure you have spark on that side. Was the plug wet? Quote
cav4ever Posted January 15, 2012 Report Posted January 15, 2012 Try switching plug wires see if the left side acts up Quote
Jackl Posted January 15, 2012 Author Report Posted January 15, 2012 i tried swapping wires still same problem set plug on top of head have spark. right side is firing, smoke out that side it coughs puffing sound its hard to explain. right side gets reallly hot really quick and not firing right. pulled choke out to see if it was fuel seems like a fuel problem but I dont really know what a stuck ring or broken piston would do. legt side runs right side cough puff sucking sound checke boots no cracks. what do I do just pull it all down and see what I find? Quote
edgehanger Posted January 15, 2012 Report Posted January 15, 2012 Check carb and reed. If all checks out do a compreesion check. If compression is good do a leak down. Quote
Jackl Posted January 15, 2012 Author Report Posted January 15, 2012 good call pulled plug, put finger over hole kick over zero compression on that side, so now what hole in piston stuck rings, top end no problem but what about bottom end pieces of crap in there, shoot her with gas and flip her over for clean out, I mean no compressin on that side, wow. Quote
Jereme6655 Posted January 15, 2012 Report Posted January 15, 2012 Ok.... I bet you had an airleak that eventually turned into a piston with a hole in it. Id pull the top end and rebuild..... But pay attention to the pistons.... If it looks like it melted then just do the top end..... However if the piston looks like it broke.... Well.... Then its time to tear the cases apart and clean everything. Some will say to just rinse the cases out well but i dont trust this method..... Cause if you do miss a piece it can make its way back up the the top end and do the "cha-cha stop dance" all over your new pistons. Its not hard to split the cases.... Just buy the manual and youl be ok Quote
ticktock Posted January 15, 2012 Report Posted January 15, 2012 Manual posted for download in tech info section, easy download, click bing bing boom right to your computer, sucks banshee blown up but manual way to go. click link in sig for manual download. Quote
Jackl Posted January 15, 2012 Author Report Posted January 15, 2012 ok pulled top end apart right side no hole in piston ring failure whatever, ring tips bent over worn right into piston see no pieces missing, will do topend next couple weeks, damn parts aint cheap, what is a bore job on cylinders going to cost me been a long time since ive done work on a two stroke, good thing I have a raptor too. can still ride lol. Quote
wacko2000 Posted January 15, 2012 Report Posted January 15, 2012 Bore Job is usually around a 100 bucks- Don't tell anyone you ride a raptor banghead LOL Joe Quote
Jackl Posted January 15, 2012 Author Report Posted January 15, 2012 aw man I love my raptor too, best of both worlds kick a banshee and a raptor too, I do love the banshee though cant wait to get her back up and on the trails. Quote
Larry's Shee Posted January 16, 2012 Report Posted January 16, 2012 Post a pic of that piston if you could. What does cyl look like? Quote
Jackl Posted January 17, 2012 Author Report Posted January 17, 2012 (edited) piston looked good, cylinder looks good no scratching no scalding no melting, dusted look dull not shiney, leak at air filter or boots dirt in intakes between filter and carb when I took it apart, broken ring. found pieces of ring in exhaust pipe. needs top end done and better air filter set up has uni one piece can you guys recommend filter set up need to keep dirt out, it got in from tear in air filter or aribox leak and when I get this thing back together what is the best break in prodedure for the shee Thanks Edited January 17, 2012 by Jackl Quote
