manny 2004 banshee Posted January 13, 2012 Report Posted January 13, 2012 So I've finally decided that I want to trim the front fenders on my shee. I know there are different spots from where you can cut the fenders to give a different look. Can anyone post pictures of their bikes? I also need help on actually how to go about cutting them. What tools what I use, etc. Quote
troyzstang Posted January 13, 2012 Report Posted January 13, 2012 This has been covered many times here. Just use the search function. Troy Quote
SonOfSand Posted January 13, 2012 Report Posted January 13, 2012 So I've finally decided that I want to trim the front fenders on my shee. I know there are different spots from where you can cut the fenders to give a different look. Can anyone post pictures of their bikes? I also need help on actually how to go about cutting them. What tools what I use, etc. I heated up a box cutter with a flame, worked well. see results below. Took me hours to decide on the front design though. Quote
NetBSD Posted January 13, 2012 Report Posted January 13, 2012 heres mine i did with a wood saw for the ruff cut and a heated knife for finish work. took me 10 mins to cut and finish, 3 days to finally get the guts to cut them. i dont get any more mud up on me unless im moving rather fast and have the steering against the lock Quote
sidewayz Posted January 13, 2012 Report Posted January 13, 2012 use a sharpie to sketch the design . it wipes off easilly with any paint thinner, so you can change or start over as much as you like untill you get it how you want . i use a portable grinder with a cut off wheel . then clean the edges up with a file , and some sand paper. take your time , you cant put it back on ! lol. Quote
manny 2004 banshee Posted January 14, 2012 Author Report Posted January 14, 2012 I heated up a box cutter with a flame, worked well. see results below. Took me hours to decide on the front design though. what's the design on yours? Your bike is freaking badass!! Quote
SonOfSand Posted January 14, 2012 Report Posted January 14, 2012 Thanks man! I love the front, has the right amount of fender kick up, and nice angles. I can send you better pictures if you pm me your email. Quote
manny 2004 banshee Posted January 14, 2012 Author Report Posted January 14, 2012 Thanks man! I love the front, has the right amount of fender kick up, and nice angles. I can send you better pictures if you pm me your email. pm sent Quote
Starwriter Posted January 14, 2012 Report Posted January 14, 2012 My personal opinion has always been that if you don't cut your rears, you need to leave sort of a front fenderette to balance it out. If you cut the rears most of the way off, then cut the fronts all the way off. I use masking tape to lay out the lines so that the tape stays on the part you're keeping. Cut right up to the tape edge with your tool of choice. I use a cut off wheel in an air grinder, then finish with sand paper. If you scroll down to the thread titled, cut my front fenders today, there are some really good pics there. Before you lay a tool to your fenders though, you need to reduce the size of your signature pic. Quote
manny 2004 banshee Posted January 16, 2012 Author Report Posted January 16, 2012 Did you get the pictures? Oh yeah, I did. Thanks. I'm still a little hesitant because i don't know exactly how I want to cut them and I'm scared I'm going to f**k it up. Quote
SonOfSand Posted January 16, 2012 Report Posted January 16, 2012 Oh yeah, I did. Thanks. I'm still a little hesitant because i don't know exactly how I want to cut them and I'm scared I'm going to f**k it up. I had the same problem... this is what I did. I used black electrical tape to create the design on the fenders, this allows you to see the shape, then easily make small adjustments until you have it right. Then trace the tape with a fine sharpie when you have it, then cut on the line. don't be scared, it will work out, just take your time. Quote
manny 2004 banshee Posted February 3, 2012 Author Report Posted February 3, 2012 i finally manned up and chopped one side today. I would have done both but not enough sunlight after school to get too much done. i also put some new lights on and the a arm skid plates Quote
jlevasseur Posted February 3, 2012 Report Posted February 3, 2012 Here's a couple pics of my bikes. mostly race cut but one pic has a pic with a more dune cut with just a trimmed rear fender.. hope this helps. Quote
Poolman Posted February 3, 2012 Report Posted February 3, 2012 Here's a couple pics of my bikes. mostly race cut but one pic has a pic with a more dune cut with just a trimmed rear fender.. hope this helps. Your bikes are Absolutely Beautiful !!! Quote
