jeramie Posted January 6, 2012 Report Share Posted January 6, 2012 I have cleaned both carbs, removed t.o.r.s, changed both spark plugs, put fresh fuel in it and it will start right up second kick and idles but when you give it gas, it just kind of bogs out but it wont die. Im runnin out of ideas. Any suggestions greatly apreciated. And what kind of voltage should the spark plug boots be getting Quote Link to comment Share on other sites More sharing options...
jeramie Posted January 6, 2012 Author Report Share Posted January 6, 2012 Correction: t.o.r.s is not removed, just disconnected. Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted January 6, 2012 Report Share Posted January 6, 2012 did you unplug "brain" on left frame tube under tank? Quote Link to comment Share on other sites More sharing options...
yz4jdm Posted January 6, 2012 Report Share Posted January 6, 2012 sounds like TORS to me.... Is the parking brake disengaged? It will cause it to not rev up as well. Quote Link to comment Share on other sites More sharing options...
dillbilly Posted January 6, 2012 Report Share Posted January 6, 2012 my guess is parking break. make sure it is fully seated in the perch. Or cut the connection and heat shrink to keep out water. Quote Link to comment Share on other sites More sharing options...
jeramie Posted January 6, 2012 Author Report Share Posted January 6, 2012 Awesome. Thanks fellas. It was the parking break. Shes runnin like a champ now Quote Link to comment Share on other sites More sharing options...
yz4jdm Posted January 6, 2012 Report Share Posted January 6, 2012 Cool... Had the same issue with mine. LOL Quote Link to comment Share on other sites More sharing options...
