jeramie
Everything posted by jeramie
Alright had the welded ball issue. Got all the parts plus a pancake bearing and shifter star mod. Put everything together, got a whole handfull of clutch, pressure plate is engaging and disengaging (moving in and out with hand lever atleast) so I put it all back together and put oil in it and fire it up, pull in the clutch, kick it in gear and she takes off. The only problem is the clutch is pulled in. WTF. Anybody have any ideas what the problem is? I'm gonna check and make sure none of the clutch plates and discs are stuck tovrther but I'm 90% sure they're all good. I'm about 98% sure they are all good. I'm pretty sure I checked one night when I had a little too much to drink.
pancake bearing.... more help (adjustment)
jeramie replied to jeramie's topic in Banshee Repairs and Mods
I'm havin a hell of a time getting the arrows to line up. I must be doing somethin wrong. I'm givin up for tonight. Anymore advice/instructions would be great. Not gonna lie, I already put it back together with the arrows not lining up. Losing patience big time. If I get some great advice, ill take it back apart if not I'm gonna tell my buddy good luck.. -
Do I torque down the pressure plate bolts THEN adjust the actuator arm? Should I have the hand lever adjuster adjusted all the way in or all the way out when doing this? This is where I'm at so far↓ http://s1047.photobucket.com/user/jeramie_licklider/media/20130430_231528.jpg.html
Alright finally got it out. Drilled it out and tapped in a torx bit and put a ratchet on it. Now, to try to find a new screw today.....
In the middle of doing a pancake bearing install and decided to do the shifter star mod. The screw is stripped to shit. Cant really get a dremel in there to put a notch in it for a flathead. Any ideas where I should go from here
The original actuator seems to be intact. Man I'm havin a hell of a time with this though. I got the actuator in, put the rod and ball in, now I'm confused again. So does the clutch basket go on, then the pancake bearing or what? I'm very mechanically inclined but I don't have the book for this bike to see any schematics.
After further inspection, I stuck a magnet down in the actuator hole and came out with a chunk of metal abou a qharter inch wide and an eighth inch long. I believe it may be part of the push rod? Maybe it mushroomed then broke off?
Cleaned, greased, no luck. It don't want to go in at all. Is there a certain position it needs to be in to slide in correctly (engaged or disengaged position)?
You can't install the arm first? I haven't put anything back together yet. I gotta order a new ball and rod
Ok thanks. Thats what I thought. Should the clutch actuator arm go in nice and easy or is it a pain in the ass? Its not wantin to go in for me.
Doing a pancake bearing install on a buddies bike. Do you have to re-use the original rods? All it came with was like a 3 inch threaded rod and the bearing and the part that pushes the clutch basket. This is very confusing and it didn't come with any kind of instructions. I know this is a common mod so someone can probably give me some instructions. I included a link to show exactly what I got. http://s1047.photobucket.com/user/jeramie_licklider/media/20130430_144759.jpg.html?sort=3&o=0
clutch pushrod welded. need help please
NICE. I wish thumpertalk was as helpful with the timing issue on my yz450f as you guys are on here. This forum is amazing. Thanks guys -
Lol good advice but I mean after I get the actuator out, what then. I can't find any schematics or diagrams on this clutch system. I don't have the manual either. I just need some direction. What am I getting myself into? -
I'm working on a buddys bike. The clutch actuator on top of the case was stuck so I took the clutch and basket out and the pushrod and ball came out. Where do I go from here? Somebody please tell me I don't have to split the case.
radiator in st charles/st louis MO area
jeramie replied to jeramie's topic in For Sale - Parts & Accessories
Found one. Love this website. Thanks -
Goin to st joe this weekend and my banshee has a hole in the radiator. If you have one for sale at a reasonable price, give me a call please. Thanks -jeramie 636-627-1388
99 shee starts and idles but doesnt rev up
Awesome. Thanks fellas. It was the parking break. Shes runnin like a champ now -
Correction: t.o.r.s is not removed, just disconnected. -
I have cleaned both carbs, removed t.o.r.s, changed both spark plugs, put fresh fuel in it and it will start right up second kick and idles but when you give it gas, it just kind of bogs out but it wont die. Im runnin out of ideas. Any suggestions greatly apreciated. And what kind of voltage should the spark plug boots be getting
i need 1 stock headlight for a banshee. cheap. it would be nice if i could get this by tuesday because were going to little sahara, OK and i dont want to have a goofy lookin bike ha
do you have stock headlights?
