Nutwood 472 Posted December 31, 2011 Report Share Posted December 31, 2011 ok cool..so the ruling is basically i dont need it..thats good to know. now finding these 2 screws is what im worried about. dont see them anywhere. guess ill keep looking. thanks everyone a bunch. cause i had no idea. that clip is a bearing retaining clip to keep the bearing from walking back and forth on the shaft,it is needed Quote Link to comment Share on other sites More sharing options...
Jereme6655 Posted December 31, 2011 Report Share Posted December 31, 2011 that clip is a bearing retaining clip to keep the bearing from walking back and forth on the shaft,it is needed Nut..... It's Is a bearing retainer...... But the bearing that goes there are has its own bearing retainer clip designed into the the bearing itself.... That's what the tab in it does Quote Link to comment Share on other sites More sharing options...
Nutwood 472 Posted January 1, 2012 Report Share Posted January 1, 2012 Nut..... It's Is a bearing retainer...... But the bearing that goes there are has its own bearing retainer clip designed into the the bearing itself.... That's what the tab in it does oh yeah i forgot about the circle clip on that bearing,lol thanks jerme Quote Link to comment Share on other sites More sharing options...
jbooker82 Posted January 2, 2012 Report Share Posted January 2, 2012 which is totally retarded.. Well if you needed to get in there for a quick shift fork fix it might be handy. Quote Link to comment Share on other sites More sharing options...
triplethreat Posted January 2, 2012 Report Share Posted January 2, 2012 which is totally retarded.. i had a guy bring me a case half last summer. most of it was torn apart and the clutch basket was still ont he shafts. they had beat on the cases till that clip snaped in half... WOW camatv is right. the only way those break is if someone leaves it on the two halves when they "beat" it apart Quote Link to comment Share on other sites More sharing options...
aleyesonme Posted January 3, 2012 Author Report Share Posted January 3, 2012 camatv is right. the only way those break is if someone leaves it on the two halves when they "beat" it apart Well peeps....I finally got the clutch basket off..and I see where exactly that piece goes.... So I'm lookingd for the screws and noticed that both of the screws heads were missing and the screws were in the the holes....so I'm looking for the heads of the screws and no where to be found...guessing they had to escape somehow even more stumped why both the heads came off....oh well seems to be all good so I'm putting it back together...thanks everyone. I needed that. Quote Link to comment Share on other sites More sharing options...
