How big is your son weight wise, what and were do you ride ,what pipes do you have....????? Ten mill motors are awesome but it hard to beat a lot of the 4 mill motors. If yourson is 120 lbs I would say 4 mill for sure, money spent to HP made they are the best. But if your son is 6'4 220lb maybe a 10 mill would be better fit. Both motors are extremely reliable and take about same parts except for the crank.
What's your son's riding experience level ??
Either way your gonna need new pipes, carbs, intakes, clutch work, 10 mil will need cases trenched, trans work, high quality chain / sprockets. So it's not just quite as simple as putting in a crank and bolting on cylinders.
It's going to be a fairly expensive endeavor.
Mike
