LooseNUts Posted September 17, 2011 Report Share Posted September 17, 2011 Hey all. pretty new to the banshee stuff. but i have a question. first whats done to the bike K&N two into one T-5 pipes Ricky stater timing +4 jetted not 100% sure on size. carbs are in sync!! no hesitation when warm and at idle and when you wrap out the throttle but when its under load it has a hesitation when you hit the go button and then takes off. how do i get rid of this? Quote Link to comment Share on other sites More sharing options...
Drturbodiesel Posted September 17, 2011 Report Share Posted September 17, 2011 Well there's different ways to go about troubleshooting this problem. The very first thing I would suggest is testing static compression. Especially if this bike is new to you. If that tests good then I would test for vaccum leaks then I would move on to fuel and ignition. But that's just my opinion. Some guys will tell u all different things to check first and they are not wrong at all. I just start at the main things and rule them out first then move on from there. Hopefully u only have a fuel or jetting issue but ur going to go around in circles if u start messing with that stuff and u don't have a solid base engine. Just my opinion good luck Quote Link to comment Share on other sites More sharing options...
LooseNUts Posted September 18, 2011 Author Report Share Posted September 18, 2011 thanks i will check on those things. Quote Link to comment Share on other sites More sharing options...
LS3 Machine Posted September 18, 2011 Report Share Posted September 18, 2011 Hey all. pretty new to the banshee stuff. but i have a question. first whats done to the bike K&N two into one T-5 pipes Ricky stater timing +4 jetted not 100% sure on size. carbs are in sync!! no hesitation when warm and at idle and when you wrap out the throttle but when its under load it has a hesitation when you hit the go button and then takes off. how do i get rid of this? Is the hesitation in the mid range? If it is it is probably the needle (assuming everything is in good working order). Quote Link to comment Share on other sites More sharing options...
LooseNUts Posted September 21, 2011 Author Report Share Posted September 21, 2011 (edited) Is the hesitation in the mid range? If it is it is probably the needle (assuming everything is in good working order). it only when I'm trolling around and then jump on it. it hesitates first then takes off. mostly notice between 1st and 2nd. if I'm in first just cruising around and want to try and pull a wheelie or hammer on it, then it does it Edited September 21, 2011 by LooseNUts Quote Link to comment Share on other sites More sharing options...
LooseNUts Posted September 21, 2011 Author Report Share Posted September 21, 2011 other than that the bike runs flawlessly. first bike ever so I'm way new to the 2-stroke stuff. oh yeah I'm at 0 to 500 foot level fkn love it tho, so much fun in the sand. Quote Link to comment Share on other sites More sharing options...
LS3 Machine Posted September 21, 2011 Report Share Posted September 21, 2011 it only when I'm trolling around and then jump on it. it hesitates first then takes off. mostly notice between 1st and 2nd. if I'm in first just cruising around and want to try and pull a wheelie or hammer on it, then it does it So if you are near idle and try to accelerate away smoothly, it hesitates, then goes? If it is this, Im going to guess maybe partial clogged pilot jet... if it is a mid range bog, Im going to say needle clip position. If you have T5s, and not much else on the bike, it prob has the toomey perfect jet kit, which is very good jetting setup. Testing in first or second gear is not good, as the gearing helps out too much with the acceleration. Best to test in 4th or 5th from low RPM. We need accurate and detailed description of what the bike is doing... what RPM range/throttle position... etc... Quote Link to comment Share on other sites More sharing options...
LooseNUts Posted September 21, 2011 Author Report Share Posted September 21, 2011 If im in 1st or 2nd gear and roll out smoothly I have not hesitation. Its only when I hit it hard. Only real thing done is what I said above. Was told it got T5 and a jet kit. The bike runs smooth other than what I explain. I will check at 4th or 5th gear next time explain and see what RPM im at by gessing tho.. Quote Link to comment Share on other sites More sharing options...
700vflash Posted September 21, 2011 Report Share Posted September 21, 2011 sounds like the low speed jetting is off, I would check the jets just to know what sizes you are running. Quote Link to comment Share on other sites More sharing options...
LooseNUts Posted September 21, 2011 Author Report Share Posted September 21, 2011 I know the main jet is a 310 Quote Link to comment Share on other sites More sharing options...
LS3 Machine Posted September 22, 2011 Report Share Posted September 22, 2011 I know the main jet is a 310 Well the main sounds a size or 2 too big, there is a good chance that the pilots are a size or 3 too big. It seems that people are so paranoid that the jet these things too big all the time. Quote Link to comment Share on other sites More sharing options...
LooseNUts Posted September 22, 2011 Author Report Share Posted September 22, 2011 What size would you recomed on both? Quote Link to comment Share on other sites More sharing options...
LS3 Machine Posted September 22, 2011 Report Share Posted September 22, 2011 What size would you recomed on both? 25/300 Check out the jetting forum. Also make sure you do the following: 1. Make sure carbs are clean 2. Check Float height 3. set air screws 1.5 turns out 4. Sync carbs Quote Link to comment Share on other sites More sharing options...
Jereme6655 Posted September 22, 2011 Report Share Posted September 22, 2011 whats your elevation? im running a 310 at 1100 ft but i also have a 2-1 air-filter, fmf exhaust, play/dune port, and +4 timing Quote Link to comment Share on other sites More sharing options...
LS3 Machine Posted September 22, 2011 Report Share Posted September 22, 2011 whats your elevation? im running a 310 at 1100 ft but i also have a 2-1 air-filter, fmf exhaust, play/dune port, and +4 timing Hes not ported, 300 should be good for him. Quote Link to comment Share on other sites More sharing options...
