01 banshee partout Aftermarket and stock
Parting out a complete 01. Engine runs, shifts good. Compression was getting low. Located near youngstown ohio. Local pickup on the frame. I can ship the rest if needed. I accept paypal or money orders. I will ship by next business day after payment.
+4 Swingarm, with chain. pc silvervein $250 pretty sure its lonestar but not 100% sure on that
+2 chrome a arms with good balljoints and tierods (not sure brand) $175
+2 Durablue Axle $125
Modquad head with 21cc domes oringed 125
Full Toomey T5 exhaust system (pipes and silencers) 250
IMS oversize gas tank blue with petcock and cap needs cleaned up (prev owner painted, i stripped most off. $75
Vforce 3 carbon fiber reeds with spacers $125
Dual filter aluminum intake / airbox $40
Ohlins front shocks (standard travel) $250
Douglas front rims nice shape $50
Protaper Se bars $30
chrome flame grill / radiator guard $30
Aluminum front bumper $30
29mm keihin PWK carbs tors eliminated with terry cables. ( Good except choke doesnt stay up) $125 for the set
Chrome stock height steering stem $60
seat custom cover $50
Heavy duty billet case saver with bolts $20
Bottom end is good, cases has the normal small peice busted from chain no leaks or issues stock stroke, good crank and bearings, good stock trans. Comes with flywheel and good stator with covers $350
Cylinders 64.5mm with pistons good shape pistons need rings. $250
Complete clutch , basket plates everything $70
Stock radiator $10
Shifter $5
Thumb Throttle $20
Ignition switch with key $20
Complete wiring harness with coil, cdi etc. (plug is cut off going to stator (was wired directly) $40
Stock rear shock $50
Rear linkage $10
Frame, Pc orange nice shape $150
Intake boots with crossover tube $20
Front wheel hubs with chrome spindles $50
Rear wheel hubs $40
Brake hub and rotor rear $20
Complete front brake assembly (master cylinder, both calipers and braided lines) $60
Complete rear brakes lever/master, braided line, caliper $60
Complete engine mount set $15
Axle carrier Good bearings $50
Stock rear wheels with 1/2 tread tires (few plugs) $50
Yellow tank cover and radiator plastic good tabs $30
Yellow tank cover $15
Orange tank cover and grill plastic $30
Black maier front fenders factory race cuts, and black radiator/grill plastic $40
Rear plastic (painted black) $20
Front plastic cut (painted black) $20
Red front plastic with tank cover and grill/radiator plastic $40
Blue tank cover $10 (cpl stress marks)
Stock seat needs recovered $10
HEadlight/ run switch works good small peice of Hi/Lo headlight switch broke off still enough there to use $15
Might have forgot a cpl things so if you dont see it listed ask . Ill keep the list updated as stuff sells. If you see it i still have it.
i have a few pics I can get pics of anything you guys are interested in just ask. I need to resize the ones i have ill do that when i get home tonight
Thanks
  • Replies 72
  • Created
  • Last Reply
Top Posters In This Topic
Hi, Very interested in the following:
Maybe even a few more parts. Please get back to me!! I can be reached at 607-644-4497. Please give me a ring!!!
I just want to talk over their condition, how to arrange either pick up or shipping. Thank you.
