banshee332 Posted September 12, 2011 Report Share Posted September 12, 2011 Ok now im a drag guy and not use to working on almost stock banshee's. I think I know the answer or answers to this but heres the question. I have a banshee that I think might be ported not sure havent checked, It has fmf pipes and k&n filter with no lid. The problem is, when you rev it up it will back fire sometimes and you can see a flame in the carbs. Any ideas? Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted September 12, 2011 Report Share Posted September 12, 2011 reeds Quote Link to comment Share on other sites More sharing options...
FullThrottle_06' Posted September 12, 2011 Report Share Posted September 12, 2011 X2 on the reeds. That is what I was giong to say. Either that, or check the timing or any factors that would relate to timing. let us know Quote Link to comment Share on other sites More sharing options...
banshee332 Posted September 12, 2011 Author Report Share Posted September 12, 2011 X2 on the reeds. That is what I was giong to say. Either that, or check the timing or any factors that would relate to timing. let us know Thanks guys. It has a stock plate the key way is fine. so its not ignition. So it has to be the reeds. Guess I will pull them out and replace..thanks again Quote Link to comment Share on other sites More sharing options...
jlsparky7 Posted September 13, 2011 Report Share Posted September 13, 2011 Reeds, water in fuel, wet air filter, exhaust leaks. Quote Link to comment Share on other sites More sharing options...
Drturbodiesel Posted September 13, 2011 Report Share Posted September 13, 2011 If no problem found with reeds I would check compression. Mine is doin sometning similar but out the exhaust. Any time you have a running/performance problem I would always rule out base engine first. It only takes a few minutes and it will keep you from chasing other possibilities if there not the culprit. That's just my opinion. Good luck Quote Link to comment Share on other sites More sharing options...
