greenskin77 Posted September 5, 2011 Report Posted September 5, 2011 i am getting on eor the other the 421 cub or the serval 421.. so whats the differnce in them has anyone used both before i have the 4mm crnak and 5 mm rod and from hot rod . i am not near any dunes or flat grounds. i do mostly hill climb and woods some slate dumps here n there. i had a 406 vitto it blew up other day so now i want to try a 421of some sort. what didnt like on the 406 was during a hill climb if i let off of the throttel and hit it again you could not get it back you eheter had to downshift or slip the clutch a lot....so that was a dislike but iliked the rev mid range was asome... so any advive on what kit i should get . Quote
EvilBanshee Posted September 5, 2011 Report Posted September 5, 2011 i am getting on eor the other the 421 cub or the serval 421.. so whats the differnce in them has anyone used both before i have the 4mm crnak and 5 mm rod and from hot rod . i am not near any dunes or flat grounds. i do mostly hill climb and woods some slate dumps here n there. i had a 406 vitto it blew up other day so now i want to try a 421of some sort. what didnt like on the 406 was during a hill climb if i let off of the throttel and hit it again you could not get it back you eheter had to downshift or slip the clutch a lot....so that was a dislike but iliked the rev mid range was asome... so any advive on what kit i should get . If you can save your jugs, Just send them away to get ported. Most 2 strokes need to be reved out pretty decent to make power. Or vito's has a new engine kit you can buy. I think its a 66mm? with the +4 stroker crank with the long rods. I have a vito 421 68mm big bore. I love it. But it makes its power up high. No low range. Alittle mid range. Quote
lms1977 Posted September 5, 2011 Report Posted September 5, 2011 get the serval it will pull the hills much better if you have to lift and get back on it but you wont get the same top end as a cub Quote
locogato11283 Posted September 6, 2011 Report Posted September 6, 2011 Cub = drag Serval = dune and woods I would recommend the Serval for you. Check the Sponsor Spotlight section. M&M ATV had some killer deals going on for Serval motor packages. Or just give them a call. Quote
dirtydownunder Posted September 6, 2011 Report Posted September 6, 2011 the serval can be ported into a cheetah cub and in between. so if you want to move your power higher, your just a port job away. Quote
camatv Posted September 6, 2011 Report Posted September 6, 2011 id do a serval with proper set up. and porting before it was even assembled.. Quote
greenskin77 Posted September 7, 2011 Author Report Posted September 7, 2011 well i got my serval kit on the way from m n m .. hope its worththe wait Quote
locogato11283 Posted September 7, 2011 Report Posted September 7, 2011 well i got my serval kit on the way from m n m .. hope its worththe wait It will be. You better invest in some adult diapers too. Quote
greenskin77 Posted September 8, 2011 Author Report Posted September 8, 2011 It will be. You better invest in some adult diapers too. hahayour the second guy on this form who told me that Quote
