codynewman13 Posted September 4, 2011 Report Posted September 4, 2011 i just rebuilt my banshee and when i took it for a spin when i went to down shift my lever went limp i can pull my lever and it moves the arm but there is no pressure between them what should i do? Quote
locogato11283 Posted September 4, 2011 Report Posted September 4, 2011 It sounds like the shift shaft is not sitting on the shift star properly. What kind of a rebuild did you do? Quote
sinisterboo Posted September 4, 2011 Report Posted September 4, 2011 (edited) detent spring on the roller for the shift star>? Edited September 4, 2011 by sinisterboo Quote
Phelps Posted September 4, 2011 Report Posted September 4, 2011 clutch arm, or shifter? take the clutch cover off and start looking. Quote
locogato11283 Posted September 4, 2011 Report Posted September 4, 2011 So you're talking about the clutch lever and not the shift lever huh? Your first post is a little confusing. Quote
codynewman13 Posted September 5, 2011 Author Report Posted September 5, 2011 i was talking about the actual clutch arm that sits on the top of your cases that your clutch lever pulls in, but anyways i figured out the problem i forgot to tighten the bolt that holds that little push pin in the center of your clutch basket but its all fixed now Quote
