Delos Posted August 14, 2011 Report Share Posted August 14, 2011 my banshee was running fine then when i gassed it really fast it began to sputter, now when i try to go in first gear it dies as i try to let the clutch out slowly. I can get out of it but it requires it to be rev'd up high. Can anyone help. Quote Link to comment Share on other sites More sharing options...
bansheesrtoys Posted August 14, 2011 Report Share Posted August 14, 2011 (edited) need more info on bike. like gearing?carb set-up?motor-setup?compession test?might need new plugs?maybe a top-end? hell the brakes can be sticking,who knows Edited August 14, 2011 by bansheesrtoys Quote Link to comment Share on other sites More sharing options...
AKheathen Posted August 14, 2011 Report Share Posted August 14, 2011 what do your spark plugs look like, too? Quote Link to comment Share on other sites More sharing options...
06specialedition Posted August 14, 2011 Report Share Posted August 14, 2011 Few things I would check first is air leaks, or a jetting problem. Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted August 14, 2011 Report Share Posted August 14, 2011 dirty carbs/air filter? Quote Link to comment Share on other sites More sharing options...
guns4children Posted August 14, 2011 Report Share Posted August 14, 2011 clean your filter. then clean both carbs one at a time and make sure you take the jets out and clean them. Quote Link to comment Share on other sites More sharing options...
Delos Posted August 15, 2011 Author Report Share Posted August 15, 2011 (edited) its a 2006 special edition..has toomey pipes and reeds, everything else is stock except shocks i guess it still has the tors you guys always talk about..don't know how to take them off so don't ask me,...don't know much about atv why hell im an electronics guy...someone suggested i clean air filters..if i take them out all together and run it in the street will that eliminate that possibility since i prob won't get dirt in them..or will that intefere with the air gas ratio?? also does anyone have a carb removal and cleaning manual for dummies...i noticed that everybody needs to clean their carb sooner or later and from what i read..its almost like seasonal or every other year..if there is no manual or instructions here why not..im really suck at mechanics a step by step would be nice.....anyways thanks for any help...if you guys need computer help, networking im your guy... Edited August 15, 2011 by Delos Quote Link to comment Share on other sites More sharing options...
volcrano Posted August 15, 2011 Report Share Posted August 15, 2011 its a 2006 special edition..has toomey pipes and reeds,...don't know much about atv why hell im an electronics guy...someone suggested i clean air filters..if i take them out all together and run it in the street will that eliminate that possibility since i prob won't get dirt in them.. u could remove it for a run up the street but dont leave it off long.uve got sticky oi/gas mixture in carb body and it will attract dust/dirt which leads to scratches in cylinder wall which leads to rebuild. Quote Link to comment Share on other sites More sharing options...
AKheathen Posted August 15, 2011 Report Share Posted August 15, 2011 well, yes, you could pull it out, but that would probably require you to go up one jet size. best way to rule out a plugged air filter is to just clean it. as for carb cleaning, it's more like when you change the oil, is probably a good idea, or a couple times a year if you ride somewhat regularly. as for the tors, that is a negative switching circuit that grounds the killswitch wire when it does not see a ground from the carbs both resting, or the throttle out of the idle position. you can disable it by unplugging the little solid state box under the gas tank. as mentioned, first thing to look at is the spark plugs. they tell you what is going on in the engine. rich, lean, detonation, head gasket, mis-fire, or no/weak spark, etc. they only last a while if you keep it tuned real good all the time, which most don't tune to the weather, and such, so it is common to simply foul a plug. you should, however pull the carbs and clean them, as well as check the jetting in there, since you haven't yet. only do 1 at a time, and don't forget to put everything back the way you took it apart. one thing to keep in mind is to drain the deposits and water out of the bowl drain screws in the bottom on a regular basis. i try to remember to do it after, and sometimes before/durring each ride. Quote Link to comment Share on other sites More sharing options...
moto4man Posted August 16, 2011 Report Share Posted August 16, 2011 my banshee was running fine then when i gassed it really fast it began to sputter, now when i try to go in first gear it dies as i try to let the clutch out slowly. I can get out of it but it requires it to be rev'd up high. Can anyone help. buy a yfz Quote Link to comment Share on other sites More sharing options...
AKheathen Posted August 16, 2011 Report Share Posted August 16, 2011 buy a yfz350 he did Quote Link to comment Share on other sites More sharing options...
jonpeter0420 Posted August 16, 2011 Report Share Posted August 16, 2011 buy a yfz Haha that's hilarious. Quote Link to comment Share on other sites More sharing options...
jonpeter0420 Posted August 16, 2011 Report Share Posted August 16, 2011 Why would you belong to a banshee forum if you don't own one. I destroy 4 chokes with my shee. Quote Link to comment Share on other sites More sharing options...
bansheesrtoys Posted August 16, 2011 Report Share Posted August 16, 2011 (edited) if your bike is tuned you shouldn't have to change your plugs often at all. i had the same plugs going on 2 1/2 yrs now and my banshee runs strong. only time you really foul a plug is because you are NOT riding it hard enough to burn the fuel or you jets are wrong causing it to over fuel. Edited August 16, 2011 by bansheesrtoys Quote Link to comment Share on other sites More sharing options...
