I bought a used bike and the person i bought it from said it has a 4mil crank in it. what is the best way to figure this out without splitting the cases? the rods have an R on one side and a 29 on the other. if that helps at all.
There are two ways that I have done before. The first is to pull the gas tank off and meaure the stroke of the crank from TDC to BDC with the butt end of a caliper, or with the tank off you should be able to pull the sparkplug and read the part number on the top of the piston to see if it is for a 4mil crank. It may be hard by eye, as I have never tried it that way, but I have an earscope that I have been using to read the fuel rings on nitrous motors and they work great for reading the part numbers too, has a light and a magnifying glass. Hope this helps.
on my 4mil it has +4 stamped on the inside of the crank right next to the rod pin
True and not true. It could be a short rod stroker, in which case it will use a standard banshee piston. BUT it will/should have a spacer plate at that point.
The only real way to know is to measure the stroke. You have no idea what somebody could have put in there.
It does have a cool head and i took the domes out about a year ago in my buddies shop and they were misplaced. I might take you up on that Koolguyson when i get some free time ill pm you and maybe we can get together so you can teach me a thing or two. Thanks for the input from everyone.
