fastcar01 Posted July 11, 2011 Report Posted July 11, 2011 Woudl it work to spray nitrous/fuel into the boost bottle? I want to use 1 BOSS NOSS NPFI. Thanks Quote
bansheesandrider Posted July 11, 2011 Report Posted July 11, 2011 You want the nitrous to be injected into the intake where there is high flow, there is not high flow inside the boost bottle. Go with your original plan of doing away with the boost bottle and injecting it into the intake boots through the crossover tube holes. Quote
fastcar01 Posted July 11, 2011 Author Report Posted July 11, 2011 ? have you got alzheimer's ? ???? I dont get it Quote
fastcar01 Posted July 11, 2011 Author Report Posted July 11, 2011 (edited) You want the nitrous to be injected into the intake where there is high flow, there is not high flow inside the boost bottle. Go with your original plan of doing away with the boost bottle and injecting it into the intake boots through the crossover tube holes. Thats kind of what I was thinking, but I am a bit nervous cause my injectors are slightly bigger than I would like to use. I would like to add abotu 20 HP, where as my NPFI's are 20 each. Total or 40 advertised, btu Dyno tests I have seen do not show that much. I went ahead and machined the plugs as originally planned, well see. I guess I was hoping since it woudl pressureize the bottle with n20/fuel it should help, don;'t forget were talking a Boss Noss system that best I can etll just lets the nitrous turn to gas before entering engine (300 PSI) Edited July 11, 2011 by fastcar01 Quote
ban565 Posted July 11, 2011 Report Posted July 11, 2011 yes it will work well. i have a nos wet system and that is how it is set upand it adjustable from 5 to 18 hp per cylinder. Quote
fastcar01 Posted July 12, 2011 Author Report Posted July 12, 2011 yes it will work well. i have a nos wet system and that is how it is set upand it adjustable from 5 to 18 hp per cylinder. You have the nozzles in teh boost bottle, or instead of a boost bottle? Woudl you by chance have a pic of how you did it? Thanks alot! Quote
ban565 Posted July 13, 2011 Report Posted July 13, 2011 (edited) the system was made that way i will to get buddy to do the pics. iam not every good at that stuff. it probably will be this weekend. the boost bottle was drilled and has nuts welded on for nozzles. Edited July 13, 2011 by ban565 Quote
n2otoofast4u Posted July 14, 2011 Report Posted July 14, 2011 You are wasting your time with the boost bottle! Quote
