Heres the problem. Its pulling great from idle till about mid to 3/4. The power just all of a sudden stops. Not pulling the way it should be at all.. heres the mods: Slip on pipes, boysen reeds, 27.5 pilots and 280 mains. I've tried the stock pilots and stock mains and everything in between. Pretty much everything else is stock. Im runnin 40:1 and i've tried 32:1. The carbs have been rebuilt and cleaned a few times and ive found nothing wrong. Floats are perfect. Pick up coil is set right and i just put a new stock coil on. It kinda feels as if timing would be off but its the stock plate. i was thinking about trying and aftermarket and adding a couple degrees and see if theres a change. any other thoughts. Its def aggravating the shit outta me. And i actually bought it this way. It just def does not have the pull of a banshee at all. Also the compression is 125 on the left cylinder and 110 on the right. I know its low on the right but that still shouldnt affect it the way its acting.
Have you tried to replace the spark plug boots? Is the stator a stock one, or is it a Ricky Stator POS? Your compression shouldn't be off that much between cylinders, so it looks like it's time for a new top end.
Yes I did a leaksown. Holds 6-7 psi all day. Def not the prob. Bike fires on the first or second kick. Stock stator and it ohms perfect. New plugs, and just put new NGk plug boots. I have also tried new stock plug boots as well.
Sorry. I forgot to add it does have a k&n filter setup. I've tried with the lid on and off and no change. With little adjustments I can notice slight differences but nothing drastic enough to gain any power where it should
DO YOU HAVE STOCK HEAD PIPES AND SOME WACKO SILENCERS OR WHAT
are the slides opening all the way try 300 mains.
Edited by camatv
Not sure of your elevation, but it sounds lean on the main
No I haven't yet. I guess that's gonna be my next option. But I'll throw in some 300's and see if it gets any better. I'm thinkin about throwin in the stock reeds too and see if there's any change.
I would do a plug chop at WOT. You are probably either too fat on the mains or too lean. Or go up on the mains like two sizes and see if it gets better or worse. Better to be a little rich than too lean.
comp. difference between the two cylinders is way to much and the one cyl is low.Time for a rebuild!!!
The simple way to check for too lean, or too rich, is to pull out the choke, when riding, and see if it gets better, or worse. If it gets better, you are lean, and if worse, you are rich.
