03banshee20 Posted June 16, 2011 Report Posted June 16, 2011 Ok i got an 03 banshee sst pipes vf3 reeds +4 timing cool head 22cc domes ekevation is about sea level running 290 mains stock pilots. It wont start only sometimes it. Doesnt start after sitting overnight. I have to either push start it or use either which i hate doing .If it sit for 5 or 6 hours its finee. Caan someone help me with my problem tell me how to adjust the float heights and get them where there supposed to be( if there even off) i also notice on a 70-80 degre day its really doggy and not. Smooth on low end like it used to be But when it hits powerband its gone Also it was just rebuilt has 120 lbs in both cyl Quote
jlsparky7 Posted June 16, 2011 Report Posted June 16, 2011 Carbs and air filter clean? Heres a vid on carb cleaning/float setting. How do the plugs look? Stock pilots with those mods seem off do you have them turned all the way in? Quote
03banshee20 Posted June 17, 2011 Author Report Posted June 17, 2011 Thanks but ill take it apart tonight. And it seems too rich cause it runs excellent when its 60 degreese Quote
jlsparky7 Posted June 17, 2011 Report Posted June 17, 2011 Thanks but ill take it apart tonight. And it seems too rich cause it runs excellent when its 60 degreese Alright man. Post back if you need more help. Ill do my best. Quote
03banshee20 Posted June 17, 2011 Author Report Posted June 17, 2011 Alright man. Post back if you need more help. Ill do my best. thanks man. and i think its too rich but not sure because the outside of the plug like at the bottom of the threads isnt even colored at all. but the white part inside that plug thats supposed to be white is pure black. so is the hook part black and has some carbon buildup already and only been run 5 or 6 times. too rich or lean? i bellieve too rich. also im getting alot of black 2 stroke oil coming out of the exhaust in the back and up front where it meets the cylinders and it has fresh seals. wtf. lol this is a pic of what plug i use the iridiums Quote
Larry's Shee Posted June 17, 2011 Report Posted June 17, 2011 Your choice of plugs might be the problem. Do you know if what you have is even the right heat range? If there was anything better than br8 everyone here would be on it like stink on shit. Might be br8es,lol. What ratio you mixing oil/gas? Quote
