yes, theres a hand engraved code to the right of the rear motor mount on the cases, same letters and numbers should be on the top and bottom.
You can almost always notice little variances on the stator side where they machine the outside edge of the cases for the stator cover as well. The matched sets line up damn near perfect, the un-matched sets never line up perfect.
- Jared
I've run them. Never had any problems. But I've heard of people who have had crank and trans failures due to the bearing to case clearances.
- Jared
