I was Looking to find why my kill switch wouldnt work somtimes i figured it was a bad ground because the previous owner painted the frame well i came a cross this on the right front by the radiator it was pluged in and the little round thing is like a pressure with or somthing it clicks when you push it in. i was just wonder what this was and if its important .
micro switch for your parking break? or maybe is it a micro switch for a newer model banshee with brakes? (did they use a micro switch on the front brakes or did they only use one on the rear brakes?)
looks the the piece that goes in a stock thumb thottle housing for the TORS. it sense when the thottle is closed. do you still have the TORS hooked up to the top of your carbs. if so then give it give it some gas and while holding the gas push that botton motor should die. and no you shouldn't need it unless you want the TORS.
not really. if you want the TORS to work then yes if not then leave it the way it was. Me personally i would take off the whole TORS and put in idle srcews and new carb caps, it really cleans up the motor.jmo
Edited by bansheesrtoys
