Banshee Bitch Basket Posted May 31, 2011 Report Posted May 31, 2011 Hi, I'm new around here and i tried searching for help but came up empty handed. The water pump seal went out on my banshee over the weekend and leaked into the case making a mess that resembles elmers glue. I am going to replace all the seals and the clutch while im in there. I want to know what the best way to flush the crankcase out is? I dont want to end up ruining a new clutch in the process. Should i run the old clutch and change the fluid a few times til it looks normal? Any ideas would be greatly appreciated!! I included a picture for fun. Thanks in advance --Amanda Quote
jbooker82 Posted May 31, 2011 Report Posted May 31, 2011 that is what I would do. Just flush it a couple times running the old clutch. Just flush it with some cheap ATF type F transmission fluid. Quote
Banshee Bitch Basket Posted May 31, 2011 Author Report Posted May 31, 2011 Awesome! Thank you for the quick reply!! Quote
BUILDER Posted May 31, 2011 Report Posted May 31, 2011 Mix 50 50 oil and diesel run it for about 5 mins then drain it and fill it with new oil. It will be clean as can be. Quote
mk2dubbin Posted June 1, 2011 Report Posted June 1, 2011 i don't see the so-called picture attached for fun... you fail at the interwebnets. Quote
Banshee Bitch Basket Posted June 1, 2011 Author Report Posted June 1, 2011 i don't see the so-called picture attached for fun... you fail at the interwebnets. I tried to attach it Rupp. I will try again. I do fail at the interwebs as well as failing with banshee's and corrados. Quote
Larry's Shee Posted June 1, 2011 Report Posted June 1, 2011 I would do the flush couple of times, maybe even overfilling it on the flush. Long as flush comes out clean all is good. Quote
mk2dubbin Posted June 6, 2011 Report Posted June 6, 2011 just to update this thread - we resolved the coolant leak issue into the trans. turns out the previous owner hooked the overflow bottle to the radiator like normal, but put a tee in down to the clutch cover breather, and had no breather tube on the rear case. they were all messed up. we properly routed all of the breathers and overflow lines and are continuing to flush the water and coolant out. the clutch is still very sticky and hard to disengage but seems to be a little better than it was last weekend before we knew of the problem. Quote
