TimJ Posted May 19, 2011 Report Posted May 19, 2011 Just done a fresh rebuild. Mods are:Play port, v force 3 reeds, stock carbs with 360 main 27.5 pilots, noss head , 20cc domes, bills pipes, no lid on air box with k&n filter. I am at 750 ft above sea level. It idles fine and when you bring the pipes on it will scream but at low rpms both cylinders gargle. I am running 32:1 100 octane. My air screw started at 1 and a 1/2 turns I am sitting at 1/4 turn and its better but still doing it . My needle is on the next to the top knotch. Do I need to move down on the needle it was ion the middle and was doing the same. Please help? Quote
rappy660 Posted May 19, 2011 Report Posted May 19, 2011 Just done a fresh rebuild. Mods are:Play port, v force 3 reeds, stock carbs with 360 main 27.5 pilots, noss head , 20cc domes, bills pipes, no lid on air box with k&n filter. I am at 750 ft above sea level. It idles fine and when you bring the pipes on it will scream but at low rpms both cylinders gargle. I am running 32:1 100 octane. My air screw started at 1 and a 1/2 turns I am sitting at 1/4 turn and its better but still doing it . My needle is on the next to the top knotch. Do I need to move down on the needle it was ion the middle and was doing the same. Please help? try going to the middle with the needle. It also seems like your mains are too big as well. I had almost the same mods, except t5s and open pod filters and i had 310 mains at 1500 feet. Im thinking you should be like a 320. Just my 2 cents Quote
sleeper06 Posted May 19, 2011 Report Posted May 19, 2011 A play port can mean diffrent things,certain builders play ports can be jetted as high as 340-360,if your 1 turn out an it runs better,try a 30 pilot,but b4 i would do that I would try richining the needle up all the way(all the way to the pionty side) Quote
TimJ Posted May 23, 2011 Author Report Posted May 23, 2011 I went with 32 pilots now i am boging bad and really bad throttle response. (needle clip is on bottom groove) I am going to try to drop some on my mains and see what happens. Any advice? Quote
Zwiser Posted May 23, 2011 Report Posted May 23, 2011 buy the tommey jet kit, it smooths everything out. Quote
rappy660 Posted May 23, 2011 Report Posted May 23, 2011 27.5, middle clip, 320'ssss your are NOT LEAN. trust me. let me no how it runs once u try this Quote
TimJ Posted May 25, 2011 Author Report Posted May 25, 2011 27.5, middle clip, 320'ssss your are NOT LEAN. trust me. let me no how it runs once u try this I put 340 main and it woke up. Already had them now i have some 320 main will see what that does next. Quote
