sebas1000 Posted May 14, 2011 Report Posted May 14, 2011 Hi my 08 banshee has fmf fattys with pc2 vforce 3 k&n dynojet kit cool head with 21cc dome . My next mods are pro design timing plate and bigger carbs . Now the timing what would benifit more from + 2 or + 3 or + 4 which would be safer and Wich more power .as for carbs I was gonna get 38 mm keihin would that be too big for my setup or what would be better . I just don't wanna be buyin more bigger carb once I put 4 mill crank bigger cylinder and ported head n cylinder can I still run them 38 mm with what I got now and not hurt my performance or anything at all . Any info will be appreciated thx Quote
Larry's Shee Posted May 14, 2011 Report Posted May 14, 2011 What do you mean by "bigger cylinders" ? What type or riding do you do? IMO, 38 would be to big for anything but all out drag. Quote
Toomey Banshee Posted May 14, 2011 Report Posted May 14, 2011 If your motor is still stock and not yet ported, those enormous 38's aint gonna work. The stockers are actually very good carbs and work well with mild porting. Your next mod should be some type of porting to match the riding you plan on doing. Quote
sstaton1983 Posted May 14, 2011 Report Posted May 14, 2011 im running a 4 mill passion port with 170psi compression,cpi pipes with pod filters and still on stock carbs.unless you are gonna go for all out drag racing where all your power is on top end you will not need bigger carbs. especially 38s with those fmfs. Quote
sebas1000 Posted May 14, 2011 Author Report Posted May 14, 2011 im running a 4 mill passion port with 170psi compression,cpi pipes with pod filters and still on stock carbs.unless you are gonna go for all out drag racing where all your power is on top end you will not need bigger carbs. especially 38s with those fmfs. Quote
sebas1000 Posted May 14, 2011 Author Report Posted May 14, 2011 I do mostly trail riding, so what kind of advanced timing would be better for my setting. i was planning to put a big bore kit and port them instead so i dont think ill be porting my stock cylinder unless you guys think ill get good gains from porting stock cylinder and head Quote
gotta_goatsfast Posted May 15, 2011 Report Posted May 15, 2011 The limiting factor is budget. I wouldnt spend the extra money on big bore cylinders without running a 58mm stroke. Pick up a stroker crank (58mm stroke, 115mm rod) and have your stock cylinders ported by a site sponsor. If you can afford more, I suggest the 421 serval. Lots of power everywhere. Quote
06specialedition Posted May 15, 2011 Report Posted May 15, 2011 I do mostly trail riding, so what kind of advanced timing would be better for my setting. i was planning to put a big bore kit and port them instead so i dont think ill be porting my stock cylinder unless you guys think ill get good gains from porting stock cylinder and head +4 on the timing is safe and what most guys run. Like the other guys said, stock carbs work just fine on a ported motor. I still run stock carbs on my wildcard aggressive ported stock stroke with great results. Porting your stock cylinders will give you big gains over what you have now. I had Wildcard Racing port mine and I couldn't be happier. If I was going to run a different setup than what I currently have....It would probably be a 4mil Serval. Quote
camatv Posted May 17, 2011 Report Posted May 17, 2011 ........................................................................... ........................ .......... ........... ............. .............. these are my eq's setting on my epod it stil has too much basss whats wrong? Quote
