jonvia Posted April 27, 2011 Report Posted April 27, 2011 im at a 65.5 bore with the pro x pistons. could i change these out for high comp pistons without having any problems? Quote
tedd1 Posted April 27, 2011 Report Posted April 27, 2011 You would have to change domes or shave head to increase compression. Quote
robert.b.west Posted April 27, 2011 Report Posted April 27, 2011 I have never seen high comp. pistons for a banshee. Did you have some in mind? To raise comp. you either have a cool head and select smaller dome sizes or have your stock head milled. Quote
mopar1rules Posted April 28, 2011 Report Posted April 28, 2011 I believe its either namura or vertex that makes high comp pistons for the banshee. They are out there, as I've seen them before, but I would rather see you change out the domes or shave the stock head, to increase sompression. Nobody mentioned either that a thinner base gasket will increase compression. Quote
mopar1rules Posted April 28, 2011 Report Posted April 28, 2011 i guess its namura....... http://www.mfgsupply.com/ATVEngineYamNamura.html you should also be able to get them from marshall distributing. Quote
jonvia Posted April 28, 2011 Author Report Posted April 28, 2011 i guess its namura....... http://www.mfgsupply.com/ATVEngineYamNamura.html you should also be able to get them from marshall distributing. so you guys think it would be best to just get a cool head and domes rather than a high comp piston? i was just surious lol Quote
casket77 Posted April 28, 2011 Report Posted April 28, 2011 I would check to see what compression your at now before you just order a cool head with random domes. Quote
FORMULASPEED Posted April 30, 2011 Report Posted April 30, 2011 i personally dont know anyone who has had good luck with Namura pistons, including myself. Good chance you will be doing your top end over again. Quote
bansheesandrider Posted April 30, 2011 Report Posted April 30, 2011 (edited) I would like to know what makes those Namura pitons "high compresion", they look just like the stock pistons to me. They probably call them that becuase your compression goes up when you bore it and install them and end up with a better ring seal. I always thought you could not get high compression pistons for a 2 stroke because when you start changing the piston top to get high compression, you fuck up the port timing in a 2 stroke. Edited April 30, 2011 by bansheesandrider Quote
FORMULASPEED Posted April 30, 2011 Report Posted April 30, 2011 I would like to know what makes those Namura pitons "high compresion", they look just like the stock pistons to me. They probably call them that becuase your compression goes up when you bore it and install them and end up with a better ring seal. I always thought you could not get high compression pistons for a 2 stroke because when you start changing the piston top to get high compression, you fuck up the port timing in a 2 stroke. Side by side comparison their the same as Vitos power pistons. But the vitos dont break like Namuras do. Quote
fastquad02blaster Posted April 30, 2011 Report Posted April 30, 2011 I would go with a cool head or shave your stock one down. Then you wouldn't have to mess with taking your motor apart and you will have options on compression by changing domes. Quote
