Porting is the best bang for the buck power mod for the banshees. Adding the normal bolt-ons to porting makes the complete package. Give kevin at Herr Jugs Racing a call and he will take care of you. He does some awesome port work. You won't be disappointed.
Porting
Pipes
Timing advance
Cool head
Reeds
Carbs
Those are the basics. Kevin can hook you up with all of them.
Porting
Pipes
Timing advance
Cool head
Reeds
Carbs
what are the best of these
Porting
Timing advance
Cool head
Reeds
Carbs
Shocks
how much would all these be and what are the best brands styles ECT.
***** -limited budget-*****
:cheers:
okay.....try the search button next time......we cover this about 1-2 times a week......just getting frustrated.
you wanna know what the best mod is for the price? porting.
Porting about $300-$400 if you don't need a rebuild
Timing advance - Free if you know how to read and can look in the mods section....there's a sticky
Cool head - $100-300 depending if new and w or w/o domes.......it can help make power but you may wind up having to buy race gas depending on dome size you choose
Reeds -$30-300... only help with throttle response really.....
Shocks - don't help with power but you can't use the power if you can't hand the bumps
Carbs - why carbs? your stockers will handle up to 70 hp.....and if your askign what mods will have more power then you don't have anywhere near the power....
You need to get all your bolt ons before you even think about porting IMO.
X2 on carbs, your stockers will run fine up too 70HP. My bike is about 65HP and runs great with the stock carbs.
I think that definately off of that list, you should do timing and reeds. Timing is probably the cheapest way to get a little more power. I think that the reeds make them more rideable. After you've done all the bolt-ons that you can, then go with a good port job.
i also wouldnt spend money on a coolhead unless you had a specific need for one. thats a fair bit of money for the little to no gain you get.
