Bansheeejohn Posted April 25, 2011 Report Posted April 25, 2011 bike has been in shed for 4 months.... K&G clutch has 5 rides on it bike has a Hinson basket, started bike after letting her warm up I put her in 1st gear she jerked then stalled after that I tried to adjust clutch cable on perch with 0 results...clutch lever feels normal tranny fluid looked good so did level clutch is not holding at all I appreciate any help thanks! Quote
bigblockbanshee Posted April 25, 2011 Report Posted April 25, 2011 More pics of girl in your avatar and you will receive an answer... Quote
acroadam Posted April 25, 2011 Report Posted April 25, 2011 bike has been in shed for 4 months.... K&G clutch has 5 rides on it bike has a Hinson basket, started bike after letting her warm up I put her in 1st gear she jerked then stalled after that I tried to adjust clutch cable on perch with 0 results...clutch lever feels normal tranny fluid looked good so did level clutch is not holding at all I appreciate any help thanks! Mine does the samething. Especially when it's not fully warmed up. I have to throttle it when goin in first so that it will not kill it. After I run it thourgh the gears it's fine. My accuator arrow lines up perfect on the case too. Quote
Jereme6655 Posted April 25, 2011 Report Posted April 25, 2011 how cold was it? it could be just as simple as the tranny fluid was cold and if it is a thicker oil then it's going to grap ALOT harder.....causing it to stall your bike sometimes. it could also be that the clutch has not been rolled over into the fluid recently so it could be that your clutch is dry and it was too dry until you get more fluid up on it.... Quote
Bansheeejohn Posted April 25, 2011 Author Report Posted April 25, 2011 More pics of girl in your avatar and you will receive an answer... ha ha if i could get more pics of her id give u the answer Quote
Bansheeejohn Posted April 25, 2011 Author Report Posted April 25, 2011 * how cold was it? it could be just as simple as the tranny fluid was cold and if it is a thicker oil then it's going to grap ALOT harder.....causing it to stall your bike sometimes. it could also be that the clutch has not been rolled over into the fluid recently so it could be that your clutch is dry and it was too dry until you get more fluid up on it.... i let her warm up for 5 minutes or more then after i shut her down i was pushing bike in gear with clutch and then without feels the same.......i dont know ive owned the bike 11 years i seen it take a little while for clutch to warm up but nothing like this then again dont think shee ever sat that long either.........im gonna pull my paddles off and throw on my holeshots and try her and pray dont need any more problems! Quote
Bansheeejohn Posted April 25, 2011 Author Report Posted April 25, 2011 Mine does the samething. Especially when it's not fully warmed up. I have to throttle it when goin in first so that it will not kill it. After I run it thourgh the gears it's fine. My accuator arrow lines up perfect on the case too. im looking for a miracle when i ride her.....just never felt like there was no clutch at all before Quote
andrew3160 Posted April 25, 2011 Report Posted April 25, 2011 I had the same problem. Replaced the clutch and pushrod and ball. All fixed. Sometimes the clutch actuator that your cable goes into going into the cases can get worn out as well, so it would be a good time to check that. Some say to push the actuator arrow to the stater side of the arrow on your case when fully disengaged as well. Quote
Bansheeejohn Posted May 4, 2011 Author Report Posted May 4, 2011 fixed!!!! thank god didnt need to spend anymore money ............my nephew had a good idea to put her up on a milk crate and run her a while...well i did yesterday after almost 10 minutes idling in 1st gear and pulling in the clutch again and again she finally started working yeah baby!!!!!! Quote
lincster Posted May 5, 2011 Report Posted May 5, 2011 Dude, use punctuation. You write 1 longgggggggg sentence. Quote
Bansheeejohn Posted May 5, 2011 Author Report Posted May 5, 2011 Dude, use punctuation. You write 1 longgggggggg sentence. lol........i learned how to do that from internet..................................................................... forums thx Quote
