marsuper33 Posted April 13, 2011 Report Posted April 13, 2011 I just got 2003 banshee and was enjoying in dunes till I .............. anyway I turned it off and when I started again it was reving to then end, turned off again cleaned the sand and started it again and went home and parked the next day will checking I found out about the vibration, in low RPM the engine will be shaking, It's awful, then When i rev it high no problem at all. I took it to a shop he said that I have to jet it. anyway I jetted it cause it needed jetting as I moved from sea level city ... but still vibrating.. checked mounts and all tighten any comments???? I have only T5... Quote
Larry's Shee Posted April 13, 2011 Report Posted April 13, 2011 (edited) Kind of hard to follow what you are saying. Enjoying it till you what? Where did you clean sand from? OK, so you moved from "sea level city" , doesn't tell us where you're riding now? It didn't vibrate after you cleaned the sand but it did the next day? BTW, welcome to BHQ !! Edited April 13, 2011 by Larry's Shee Quote
Socalcasedog Posted April 13, 2011 Report Posted April 13, 2011 Only vibration ive ever had at idle was my damn under frame sheilds Quote
