Well stop running it and check it all out. Obviously something major is wrong but be my guest an run it till it blows cause thats whats gonna happen if you keep pushing it. Youve wasted atleast 2 tanks of fuel already....i woulda stopped when I felt something wrong the first time
Top end: anything above the crankcase. Yes this includes your carbs.
That being said id suggest you look at everything to make sure its all set right instead of potentially messing the engine up more by running it
the company builds a 2nd wire into there system just as an added option. If you just ran the stock AC system you would only run one of the 2 wires to your regulator. The second wired gives you the option to add more lights.
Im upgrading to some 4" HID lights so I had replace the regulator with the companies rectifier. I dont have to run both stator outputs but Im gonna kinds like a piggy back set up.
Think we paid only $250 or so for the stator an recifier. Its a small company but Ive heard good things bout them. I went to get it in person and when I told them my plan the even floated the ground for me while I waited for free.
AKheathen.....
I had figured it out. I upgraded to a 250w stator. The rec has 4 wires( ground, 2 inputs from stator and power out)
I put the quad aside for a few. Gotta make mounts and brackets for everyrhing now. I re-loomed the harness after eliminated all the bs safety wiring and ran everything through heat shrink. I seperated the lighting and pwr into seperate harnesses. Took the time and took the plugs off the wires to cover them as well. Looks soooooo clean now lol. sounds even better with +4. Figuered ikl repack the silencers while I got it apart too.
Getting antsy to ride now lol
Well logically speaking and not seeing it in frony of me, Id say your problem is in the top end. You only have the issue with one cylinder. On the seal question water wont hurt it. Thats its job to keep stuff out. Only time that seal is gonna die is if it got cooked or messed with. Theyre pretty durrable cause if they werent everyone would have to maintain them like the top ends ya know
The fuel can result from a dirty carb. Peraonally when the pilot jet gets dirty ive notices fuel build up.....if the needle is set too hi it will flood really bad too. I always leave my needle clip set in the middle. There are 5 height settings for it. Also the air metering screw ive always set 1 1/4- 1 1/2 turns out. Wirks great for the altitudes I ride but higher elevations you would need to adjust out more turns accordingly for the decrease in O2. Note that ive never riden over 2500'
Sounds kinda like its flooding itself.......im not an expert at all but id go through your carbs. Check settings of all the metering screws, needle/seat, and give it a good cleaning. Its a basic check and would only cost you the time and can of carb cleaner. You may find something there and save you from dumping a lot of money into it. I know thats something id do. Personally i go through all basics first.
Have you noticed any fuel puddling up between the slider and where the air box connects?
hows it feel on the bottom end? What mods you done? Have you checked your timing at all or to see of your flywheel key might be getting ready to shear?
Well I can only speak for myself ya know but like the other guy said, if you dont have the mod that require it then dont.
Its kinda like the kids these day that think running race fuel in there stock engines , on or off road, makes them a lot faster.....if you understand where comming from
