GOTTA PUT MY BANSHEE BACK IN THE SHOP
Check your jetting and make sure you have it jetted right before you blow up the next top end. Do a leak-down test and check for air leaks... Get your cylinders ported by Kevin at Herr Jugs Racing while you have it apart! You won't regret it at all. Best power mod you can do on a banshee.
gotta-gofast has a good point.....it really could be that you torched teh rings chances of seating right. Why can't you do the work yourself? Did they just do the work to the cylinders or did they do the ENTIRE rebuild and reassembly?
they did the entire rebuild!!!!!
