kinda hard to tell from that pic. does the it neck down at all where the flange is welded or just the same diamater?
If I am understanding you correctly, yes.
Did you click on the picture to enlarge it?
Thanks for confirmation guys.
I'm putting them on a HJR 10 mil cub, does anyone know if there is something to be gained by going to big bores?
did you pick up a 10mm?????
I wish!
No, just helping a friend do a new build in my garage, he bought the pipes used, and the guy told him they were BB.
I will probably need a 10 mil to best you though. LOL
those are small bores the flange to pipe is nearly the same on BB
most people think that just cause the pipe dia is BIG makes thema BIG BORE pipe and they are sold that way.
small bores will REV and the BB's will make more TQ on the 10's i personally like the added TQ them larger motors dont really like to rev to 13K anyways.
Is it a significant amount of TQ?
Thanks Cam.
On the other end of the pipe there is a difference. The smallbores taper down to the stinger before they really curve in towards the middle of the bike, the bigbores curve in towards each other and actually are fat still just under and inside the top frame tube. Mine actually crowd my lectrons but my 4mil likes bigbores.
For what its worth, I dynoed BB OOF vs SB OOF on my 10 mil Cub. They made the same HP, but the BB made it sooner in the rpm range, and that means more TQ. NO difference in times at the track with them, using the same tires/gearing/jetting on both. YOur results may vary.
Good to know, thanks.
