inked up Posted March 20, 2011 Report Posted March 20, 2011 hi so i got a 2002 banshee and it moded pretty much everything you can do : and when i drove my buddy banshee its like the power is always there just as you hits it , and its totally stock . but my is i hit the gas and its a sec or two and then it kicks in .. would that be the boost bottle or...... please help Quote
Surfrjag Posted March 20, 2011 Report Posted March 20, 2011 proboboly a jetting issue. have you done a plug chop to see? i dont know much about boost bottles.. Quote
inked up Posted March 20, 2011 Author Report Posted March 20, 2011 (edited) plug chop?...............like my bike got everything done , pipes , bored out , filter , etc but i dont think its jetted Edited March 20, 2011 by inked up Quote
06specialedition Posted March 20, 2011 Report Posted March 20, 2011 but i dont think its jetted Thats not a good thing. Do you know your current jetting? or how to check? Quote
sstaton1983 Posted March 21, 2011 Report Posted March 21, 2011 is this a joke? boostbottle needs recalibrated,here is a how to,push throttle 3 times within 5 seconds and pump brakes twice.. lol Quote
vifferman Posted March 21, 2011 Report Posted March 21, 2011 I believe Surfrjag is talking about running at high speed in 5th or 6th gear for 50 yard or so and pulling in the clutch and turing off the motor with the kill switch. Don't fire it back up again before pulling the plugs to see how they look. Jetting is complicated, getting a manual would be helpful as it is difficult to adjust jetting via the internet. Quote
inked up Posted March 21, 2011 Author Report Posted March 21, 2011 Thats not a good thing. Do you know your current jetting? or how to check? dunno and no not sure how to check Quote
sstaton1983 Posted March 21, 2011 Report Posted March 21, 2011 dunno and no not sure how to check pull the carb bowls off.you will have two jets in each carb the bigger one in the center is the main jet and the pilot will be in a smallerhole in front of it.the jets will have a number stamped on them.also you can rfemove the slide and check the needle too.now do you have stock carbs?and saying it is fully built is a broad statment in the banshee world. Quote
gotta_goatsfast Posted March 21, 2011 Report Posted March 21, 2011 dunno and no not sure how to check Okay, I'm assuming you haven't "moded pretty much everything you can do" if you can't figure out what jets you have in your carburetors. I suggest digging into your carbs and find out what jets are installed. Your original post sounds like a lean condition whether it be from insufficient jetting or an air leak. Boost bottles, for instance, are a notorious for cracking your intakes and causing a fatal air leak (and they really don't do anything for performance btw). Anyways, your next post should include exactly what has been done to your banshee motor wise, what the air temp is, what the elevation you ride in is, the current jets, and that you have confirmed it passed a leak down test. There is plenty of information on BHQ already explaining how to check your jets and how to perform a leakdown test. Browse through the stickies at the top of each section. Quote
inked up Posted March 22, 2011 Author Report Posted March 22, 2011 ok i got a guy that does my motor and stuff llike that ... So what do you need to know i get him to check everything ....so ye can help me ? Quote
gotta_goatsfast Posted March 22, 2011 Report Posted March 22, 2011 Look man we're trying to help you but you're not helping us (to help YOU). Maybe your guy can help you out since he built your motor and stuff. Quote
