acroadam Posted March 17, 2011 Report Share Posted March 17, 2011 I can't post pics for some reason...but I need someone who can tell me what this is...it came out while I was draining my trans oil. Just post ur email then I can email you the photo...thanks Adam Quote Link to comment Share on other sites More sharing options...
acroadam Posted March 17, 2011 Author Report Share Posted March 17, 2011 I can't post pics for some reason...but I need someone who can tell me what this is...it came out while I was draining my trans oil. Just post ur email then I can email you the photo...thanks Adam If you don't feel comfortable sharing your email address, just pm it to me...I need help asap....I'm trying to figure out photo bucket Quote Link to comment Share on other sites More sharing options...
HardLuck Posted March 17, 2011 Report Share Posted March 17, 2011 Quote Link to comment Share on other sites More sharing options...
acroadam Posted March 17, 2011 Author Report Share Posted March 17, 2011 Thanks hard luck........does anyone have a clue. The only reason i drained my oil was because I seen that my drain plug was leaking a little out, so I ordered a new drain plug...nothing was rattling...it's a fresh rebuild, maybe a couple weeks, if that. But it did sit for 2 years before i did the rebuild..but after the rebuild, it's pulling great . The only thing that maybe wrong is that when it's first warming up I put it in 1st gear and jerks real bad and dies..but if I give it gas and push into first gear it's fine...then after five min of ridiing, 1st gear is fine.. Quote Link to comment Share on other sites More sharing options...
BigRed350x Posted March 17, 2011 Report Share Posted March 17, 2011 It holds the shift star in place on the drum. Sounds like time to pull your side cover and get the clutch off & check out your shift linkage and star. Hope that helps. Quote Link to comment Share on other sites More sharing options...
acroadam Posted March 17, 2011 Author Report Share Posted March 17, 2011 Thanks big red. Is that something that usually happens? I have a clymers, should i look thourgh it as I go thourgh my clutch? And what's it gonna be that i have to replace? The shift star? Thanks Quote Link to comment Share on other sites More sharing options...
acroadam Posted March 18, 2011 Author Report Share Posted March 18, 2011 Thanks big red. Is that something that usually happens? I have a clymers, should i look thourgh it as I go thourgh my clutch? And what's it gonna be that i have to replace? The shift star? Thanks Thats what it was. Pin dowel for my segment. The bolt holding the segment was loose. Would it be ok to use lock tight on that screw? Quote Link to comment Share on other sites More sharing options...
Jereme6655 Posted March 18, 2011 Report Share Posted March 18, 2011 Thats what it was. Pin dowel for my segment. The bolt holding the segment was loose. Would it be ok to use lock tight on that screw? yea that's fine. Quote Link to comment Share on other sites More sharing options...
