ranger505 Posted February 26, 2011 Report Posted February 26, 2011 i have a 99 banshee i recently about 3months ago rebuilded the motor new hot rod crank new pistons fresh bore new stator new coil cool head size 22 domes original carbs no tors single kn filters t5 pipes. it starts right up idles and sounds real healthy but when i reev it up it sputters ral bad. i had some guy tune the carbs but he tuned it where it should be and it still sputters i tried bigger jets i also tried smaller jets and it still sputters any ideas what it could be Quote
gstaten24 Posted February 27, 2011 Report Posted February 27, 2011 What is you're jetting at right now? (main, pilot, air screw, needle clip position) also what is you're elevation. It's probably a jetting issue if you changed anything like added new pipes or any modifications really. Did u do a leak down test before u started it? Also is the tube that goes between the carbs there? Quote
troyzstang Posted February 27, 2011 Report Posted February 27, 2011 What is you're jetting at right now? (main, pilot, air screw, needle clip position) also what is you're elevation. It's probably a jetting issue if you changed anything like added new pipes or any modifications really. Did u do a leak down test before u started it? Also is the tube that goes between the carbs there? Disconnect the ebrake plug right behind the radiator & you should be fine. Good luck. Quote
ranger505 Posted February 27, 2011 Author Report Posted February 27, 2011 260 jets good compession Elevation 5,312 ft (1,619.1 m) i took it to a yamaha dealer here in albuquerque and they jetted it but couldnt tell me whats wrong with it Quote
gstaten24 Posted February 27, 2011 Report Posted February 27, 2011 Hmm weird. Well when I had just t6s on my bike here in clovis I was running a 290 main jet but I have pods so idk how big of difference that would make in jetting compared to you're single. Did you try unplugging the ebrake like Troyz said? Quote
ranger505 Posted February 27, 2011 Author Report Posted February 27, 2011 what is the ebrake sorry Quote
troyzstang Posted February 27, 2011 Report Posted February 27, 2011 what is the ebrake sorry If your bike has the stock clutch lever there will be a wire coming off of it that will go to a plug right behind the radiator. Follow it down from the clutch lever to that location and disconnect it. Then try to start the bike. Quote
sleeper06 Posted February 27, 2011 Report Posted February 27, 2011 t-5 set up 280-290 main 27.5 pilot needle 4th clip,if your going up n down with jetting n still having same issue chances are its electrical.I would try the jets i suggested then move on to electrical being you stated stuff is new Quote
ranger505 Posted February 27, 2011 Author Report Posted February 27, 2011 i dont have no wire coming off the clutch, ive tried jeting it differant ways i even put my friends carbs on and it sounds better but only at idle when you give it gas it sputters. i looked at my herness it looke good all connectors look ok bolth wires are getting good spark. a friend of mines told me that maybe its the crank he said the crank might of spunn but its new its not welded but i really havent even got to enjoy riding it any other ideas it sucks i probly have about over $2500 in the motor and i cant even enjoy it. Quote
Larry's Shee Posted February 27, 2011 Report Posted February 27, 2011 (edited) The F A I L was for taking it to the stealer and paying for nothing. First thing do do is make sure they did not put stock jets back in You changed NOTHING during rebuild? Porting, pipes, air cleaner, domes, oil/fuel ratio ? Did you do a leakdown test ? What kind of stator did you get? Check that the TORS box is not hooked up, left frame rail under tank. Did you set pick-up coil gap? Did the new coil come with new plug caps? Make sure ground from stator to engine/frame and coil to frame is clean and tight. Is the choke crossover tube in place? 3inch tube that goes between both carbs across from the choke plunger. Is the crossover or boost bottle ( ) in place correctly? Double check ALL connections and switches. Consider the fact that new electrical components might be bad, might try swapping your buddys parts for testing. Coil, stator, cdi. Didn't feel like typing last night, sorry. Post back with results. Edited February 27, 2011 by Larry's Shee Quote
ranger505 Posted February 27, 2011 Author Report Posted February 27, 2011 i removed all my plastics i again went through all connections they look ok i put a rickey stator the coil i purchesed did not come with new boots i reused the old ones i gapped the stator i also tried it in differant positions. i did upgrade to the cool head. yamahe put bigger jets in Quote
fastquad02blaster Posted February 28, 2011 Report Posted February 28, 2011 It might be your stator. People on here have had problems with RS stators. Try putting your old one back in and see if that fixes the prob. Quote
