ranger505
Everything posted by ranger505
  1. the timing plate is set correctly
  2. sorry about the new thread but i have t 5 pipes stock carbs .66 bore stock reeds ricky stator ricky cdi bow 280 jets hot rod crank cool head no tors any thing else
  3. originally i checked the compression and it had 90 but the compression tester had the wrong end so i got the right one and it has about 132 the reeds look good. i was messing with it know and i had a long screw driver on the motor and i see arcking off of the motor and the screw driver the more i rev it up the brighter it gets any ideas
  4. im reposting my issue im having with my banshee 1999 my banshee starts up first kick idles great but when you reeve it up it bogs down it seems like it misses sometimes back fires. it has a new crank fresh bore new coil new stator cool head 22 domes new pistons i has a cdi box on order and i received it but it still does the same thing ive had 2 people tune it for me and they could not make it run right now i have 280 jets we moved the needle all positions and the same. some body told me that it could be the crank but its new. checked all grounds they look good i have stock carbs no tors. i was moving the idle screw and it shocked me i dont know what that was about. i really dont want to tear the motor apart. what should i do??
  5. i removed all my plastics i again went through all connections they look ok i put a rickey stator the coil i purchesed did not come with new boots i reused the old ones i gapped the stator i also tried it in differant positions. i did upgrade to the cool head. yamahe put bigger jets in
  6. i dont have no wire coming off the clutch, ive tried jeting it differant ways i even put my friends carbs on and it sounds better but only at idle when you give it gas it sputters. i looked at my herness it looke good all connectors look ok bolth wires are getting good spark. a friend of mines told me that maybe its the crank he said the crank might of spunn but its new its not welded but i really havent even got to enjoy riding it any other ideas it sucks i probly have about over $2500 in the motor and i cant even enjoy it.
  7. what is the ebrake sorry
  8. 260 jets good compession Elevation 5,312 ft (1,619.1 m) i took it to a yamaha dealer here in albuquerque and they jetted it but couldnt tell me whats wrong with it
  9. i have a 99 banshee i recently about 3months ago rebuilded the motor new hot rod crank new pistons fresh bore new stator new coil cool head size 22 domes original carbs no tors single kn filters t5 pipes. it starts right up idles and sounds real healthy but when i reev it up it sputters ral bad. i had some guy tune the carbs but he tuned it where it should be and it still sputters i tried bigger jets i also tried smaller jets and it still sputters any ideas what it could be
