let me know if you have a set of fattys for cheap no or little dings i dont care about the finish
I have a set of sst pipes... some rust near the inlets the silencers powercore 2 sst are dented up though... idk if u would want sst's :confused: but make an offer if you are interested
hold on guys just found a set of fattys in the for sale forum let me check on them first only 50 bucks i dont need them i hace dmc916 just want something different
How do you like the 916's on low end power? I wanted a set BAD until I found out they are more for mid-top end.
they are the best all around pipe imo my bike has 28mm carbs ttrail ported +4 degree rad valves and a couple other things but i have power from idle to wide open i would highly reccomend these pipes honestly i like them better than t 5s
just dont go to big on the carb youll lose all bottom end but they are great for ported bikes
and my gearing is 42/15 and all i do is trails and open feilds :bolt:
My bike is all stock, this week i'm narrowing down pipes, going to get a jet kit and the air filter adapter setup. I'm not ported, so not sure how the pipes would run on my quad. I LOVE the sound though, I am still looking for a set....if I find some and the price is right i'll pull the trigger
they are a mid to top pipe but they do not drop the bottom end like toomeys do they are a great pipe for midrange too they work great on unported motor but will combine good with any mods you do
i tried the t5 .fattys , procircuits and dmc and these are my favorite 2, is the fattys 3. pc toomeys are great pipes but they are mostly top end
