Went riding last weekend, second time at this place, throttle stuck both times. I had to smack the throttle real fast to get it to back off and the cable doesn't feel fraded and I don't have this problem around the house when riding. Any help would be greatly appreciated.
try to lubrificate the cable first
Was your quad sitting for awhile before you went riding? More than likely your slides are hanging up..Need to take your carbs off and clean them. Let them sit for awhile an they get sticky an will stick open...
i would do what mikenick said and also lube up the cables with any lube like WD40 would work but i would use more of a grease if possible though...
DON'T use grease, it is too thick. I prefer a product called Tri Flow. It is a teflon based lube that sand and dirt won't stick to.
I prefer to use "cable life" lube. If the cable is quesionable I would just replace it. Check the slides for a grain of sand or two. It doesnt take very many to cause a slide to hang up.
Edited by jbooker82
when you went riding at this place did you ever wind up running through or splashing up a little bit of water? The stock mikuni carbs are nutorious for sticking when you run them through water...
take it out riding again only make sure this time its a dry place and see if it does the same thing......then if you can.....find yourself somewhere semi-wet and try it there too and see if that's where your running into the problem. Like i said before......mikuni carbs are nutorious for binding up slightly when you run run em in wet conditions...
