Larry's Shee Posted March 4, 2011 Report Posted March 4, 2011 Thought you dropped of the planet AK. Quote
BigRed350x Posted March 5, 2011 Report Posted March 5, 2011 With all the beating you've no doubt done to the cases so far and will have to do to get them apart, I would definitely replace the cases once you have it apart. You can wedge a flat bladed screwdriver between the case halves back by the trans shaft on the clutch side. Even if you pound a driver through the case there it won't totally kill you since the trans is in the same oil the clutch is in and having a beat up sealing surface right there wouldn't be the worse spot. If I were going to try and pry them apart, that would be the spot to do it. - Jared Quote
