ok here is what i have
fmf fattys
k&n lid on
VF3's
main 260
stock pilot
air screw 1/2 turn out
needle don't know
shee screams up on the pipe but has a slight hesitation right off throttle it was 40* today so that might have something to do with it or do i need to change something
i really need to check out the needles and see what clip they are on
im thinkin i need to richin up the needle or do i need a bigger pilot
Most will recomend 27.5 pilot jets with pipes. Has it sat all winter with fuel in the carbs? Might want to clean them.
1-1.gif on the Pilots, (stock pilot, air screw 1/2 turn out) you're definitely too lean and maybe you're mains as well. You didn't say what your altitude is but the cold winter air is a LOT denser and needs bigger jets to compensate. Might want to start with 27.5's, needle clips one down from the middle (fourth from the blunt end), and 280 mains for winter riding. For summer riding, leave the pilots and needle alone (a little rich) and just drop your mains two sizes and tweak your air screws.
so your saying the setup thats in it now will be ok once it warms to around 60-70
i just cleaned the carrb and just wanted to take it out for a first spin since i got it a few weeks ago and been itchin to get it out
in summer same set up 280 main,30 pilot 2turns out on the screws stock needle all the way rich,I have a lot of experiance tuning that set up and fattys liked big pilots you could get away with 27.5 pilots with a lil portwork
ok but idk if my setup would be the same as yours in NY
It's not the state. It's the mods, elevation and air temperature. Lower elevation and temps both mean denser air and require larger jets to compensate. Adjust your jets accordingly.
Edited by muggzy
i think ill just wait till spring and warmer temps i just had the itch to get out and ride it for the first time the other day i think once the temp get around 60-70 it might be ok but i am going to wait and see and get some plugs and do a chop
