more smoke out of one cylinder
cvalcore
hi guys im new here and i have a banshee that i bought about a year ago and Ive been chasing a problem with it smoking out of my left pipe more than the right side im talking twice as much smoke i have sincked the carbs and i have had a buddy do it also Ive checked both needle valves and there set at the same level i bought new v force 2 reads i just had the engine rebuilt by k&t performance so i no the engine is good and im having the same problem the jetting in the carbs are the same???? please help!!!!
Welcome to BHQ.
Make sure EVERYTHING on both carbs are the same. Mains, needles, pilots, air screws, sync..etc
both the air mixture screws are at two full turns out and the idle screws are adjusted the same on both carbs any help to where the adjustments are would help greatly on a car or truck im very familiar with the carb on these im not sure im new to the two stroke world and trying learn all i can thanks
Edited by cvalcore
The main jet is the small brass hex one when you open up the float bowls, the pilot is only accessible when you remove that plastic piece, its slides up towards you. The pilot is tiny, and you will need a small jewellers type of screwdriver to access it at the bottom of the hole that gets uncovered(in a nutshell anyway).
ok ill check them out also
I had the same problem when I rebuilt my engine a couple of years ago and new to 2-strokes. It turned out that my jetting was off. Let us know exactly what you've got in there now - Pilot jet sizes, needle clip position and mains (nos are stamped on the jets) and what altitude and temp you're living in and what mods (exhaust, intake, etc) and we'll get you close.
ok i have the cylinders bored to 65.5 it has a cool head and V force 2 reads and i have t5 pipes it has also been ported and polished with stock carbs and intake boots the needle clip is all the way closes to the needle side and if i remember right i changed the jets to 350 jets but not possitive ill check when i check the pilot jet also but i had the same problem before jetting it. and my altitude is 4,487 feet but i have been riding in the mountains a lot on the snowmobile trails and the altitude there is 7051 feet and about 20-30 degrees the altiitudes i ride in the summer are about the same but the weather is about 70-90 degrees. so your saying i could have the wrong pilot jet size also would this cause my engine to brake a ring on that side thats why i had it rebuilt?
ok the jets are 310 and the pilots the little one is 25 and the screw on the bottom of the float bowl is screwed all the way in should it be that way?? ya the altitude is high but its fun you dont see to many banshee's. i live in utah banshee's around here are mostly used for the dunes but with the dunes being 3 hours away i ride quit a bit in the mountains and only a few times a year at jerico.
okay....the screw at the bottom of the carb bowl is a drain....you want that screwed in. unless you want gas flowing out while your bike is running or just sitting there. i THINK you may need to jump up your pilot to a 27.5......i do know the 25 is a stock pilot and aftermarket pipes require a larger pilot jet. However im not 100% sure about it since your so freakin high up in the stratosphere....geez...
lol maybe 06specialedition might no he lives in utah it looks like. so is my jetting ok? and thanks about the bowl drain! ow i ya also have k&n filters i dont no if that mattters or not.
Yeah I live about 90 minutes from Sand Mountain, UT. I think its about (5,000 to 5,200FT)
Just to give you an estimate on what jets to run, look at my mods in my profile....I run 310 mains, stock pilots, needles second notch from blunt end, air screws 1 1/2 out. I would say if your running 310's you could possibly be too rich, even with my 310's in the middle of the summer at 5,000FT I'm a tad rich and I'm running CPI's and Aggressive Dune Porting...etc.
Remember though, the colder it is outside the more fuel you need. I don't ride in this weather, so I keep my 310's in for the summer riding I do.
-Zach
