I have a crank seal leaking so I am going to do a total rebuild. My plans are:
4 mil crank
aggresive trail\flat track port
cool head with 20cc domes ( domes are maybe want to go as high as I can and still run pump gas )
if needed bore and new pistons (not sure untill I tear it down )
v-force 3 reeds
toomey t5 pipes ( have bills pipes but need replacing )
adjustable timing plate
Stock Carbs ( has 280 main jets ) I am at 130ft above sea level ) this might need changing?
K&N air filter with airbox and top ( will remove top ) after rebuild
Any more suggestion I might need are welcome.
Tim
Make sure you put good bearings on that crank. 20 cc domes are fine. Jetting is Definatly going to change. Just bore and put new pistons in it anyway since you have it all apart. O and if you dont hit to much water or ride on rainy days i would put some pod filters on it. Just to eliminate the box and what not.
