Fullthrottle02 Posted December 30, 2010 Report Posted December 30, 2010 leaking oil out the top of the case where the clutch actuator arm is inserted. My vent lines don't appear to be plugged, but i will thoroughly inspect and clean this weekend. If my tranny is being pressurized due to a case or crank seal leak, etc. and vent tubes are not clogged, why would the oil not leak out of the vent tubes? I would think it would have leaked out the vent tube first, or at least both. Quote
bigboybanshee Posted December 30, 2010 Report Posted December 30, 2010 When you're checking your breather tube in the back, be sure to also check the little white plastic piece that attaches to the case, that the hose connects to. I would pull the whole thing off and ensure it's clear on both ends. I've never seen it leak around the actuator arm before, but it does sound like your cases are being pressurized. Quote
