I ran the R-2's on my old 10mm Cub motor when I still had the original Rockets to test against. The R-2's made good bottom end power and pulled a little further on top than my Rockets. I had tested CPI vs. Rockets on an old motor on a dyno years ago and they were very close in comparison. I wouldn't doubt that the R-2's will pull just as far or maybe further than the CPI. Keep in mind, all motors and setups are different.
I too would like to see a dyno comparison. I am also looking to get different exhaust and not sure which to go with. For me, its a toss up between CPI, R2, Shearers and the new Snipers. I haven't ridden any other banshees other than mine to know what to expect for power characteristics though.
The sniper is more of a cub pipe I believe
I was under the impression that a version was being made for stock cylinders, but it was going to work best for more of a radical port job. I remember seeing a graph a while back comparing them to either Shearers or CPIs and I want to say that they came on a little sooner than the Shearers and about the same as the CPIs.
Any of those pipes are going to pull harder, rev higher and make more power than your T-6's.
