well now ive changed my mind and im getting it bored 40 over i found a top end rebuild kit from wiseco for $195.95, ill have about roughly 400 dollars after getting it bored and buying the pistons, then with that money ill try to get the crank trued and welded if i can and if i can find someone to do it, which like you guys said should be about 50 bucks, so then ill be down to 350, then ill buy the vforce3 reeds which are 220, that will put me at 130, then ill buy a full motor gasket kit and replacement stainless steel allen screws for the side covers which cost $45.45, ill be left with 85 bucks plus all the shipping costs i have to add in, so ill probably be at maybe 75 or 70 bucks, what should i buy with that much left
Extra 70 bucks...I'd get a Mull or Chariot water impeller.
dont go with a .040 bore yet man.....start at the smallest size. Otherwise your only shortening the life of your cylinders. Give Jeff at F.A.S.T. (Farmandsandtoys.com) a call and he can set you up. He can get you the correct sized top end kit for almost that price.....or even better yet....you can just send him your cylinders and he can bore/hone and chamfer the intakes (like your supposed to do) and then send you the cylinders and top end kit and everything you'll need. He is actually pretty cheap when you think of it.......he does the bore and hone for like $100 total for both cylinders.
Oh ya....and i didnt see any price in your listing for the machining cost of the cylinders which will be anywhere from $100-$180
Edited by Jereme6655
to get it bored and everything to the piston size im getting is $130, the pistons like i said are $195.95,the piston kit includes everything i need for the top end rebuild, which after those are paid for like i said ill have around $400
thanks everyone for the help
this is what i planned out so far with the money i have and i can get other things done later but for now
bored 40 over which will cost $130, top end rebuild kit $195.95, the with the other $400 dollars, crank trued and welded about $50, vforce3 reeds $220, whole motor gasket kit $30, stainless steel allen screw kit $16, billet water pump impeller and drive gear $69, ill be left with $45 which for now ill not plan to do anything with cause also i need to calculate shipping costs, and if i need something else when i get the motor completely torn apart. plus ill be getting more money for that just incase stuff.
whats the best exhaust system, i want something that sounds sweet and adds power
Your going to get a million answers with this question. It all depends on your riding style and motor set up IMO.
I run CPI's on my ported 350.
well my dad measured wrong he said it wasnt bored over but when i ran the piston numbers its bored 60 over already with a hot rods (+5mm) long rod crank, so now this is what im doing, ported for trail,vforce3 reeds, noss head need help on the size of domes i should get, what size should i go with i run premium all the time and racing fuel sometimes if i have the money,im also getting the billet water impeller and drive gear,and a adjustable timing plate, im also replacing the rings on the pistons cause the pistons are still good so i wont replace them yet
  • 2 weeks later...
trail porting cylinders and opening piston windows more $200, whole motor tear down and inspection, check the carbs and jetting $100, advanced timing plate + installing it $50, all gaskets being replaced $35.60, crank sent in to be trued and welded $92= $477.60 all done by Jerry.
parts I'm buying and installing,
Noss heads with 19cc domes= $287 w/shipping
either srp ram air reeds for $170 or im finding some vforce2s, the srps are supposed to add 1.5hp over the vforces tho
brand new rings $68
all oils and antifreeze about $25
total cost around $1027.60
anyone know how much hp this will have and what it will top out at, 1989 banshee is bored over to 65.50 with wiseco pistons,has hot rods long rod crank(+5mm), fmf gnarly exhaust with toomey t5 silencers, upp manifolds, boost bottle,cut off air box, w/ pro flow airfilter adapter and k&n airfilter, keihn 35mm carbs, gearing is 17,41, and right now getting cylinders ported for trail, piston windows opened up, all gaskets are being replaced, advanced timing plate +6 degrees, crank trued and welded, new rings, noss head and 19 cc domes, and vforce2 reeds
  • 3 months later...
my 1989 banshee is bored over to 65.50 with wiseco pistons,has hot rods long rod crank(+5mm)trued and welded, fmf gnarly exhaust with toomey t5 silencers,sparky cobra add ons, upp manifolds, boost bottle, cut plastics,carbon fiber gas tank and radiator cover,powder coated candy red frame, black plastics, twist throttle, pro taper seven eigths handlebars, cut off air box, w/ pro flow piece and k&n airfilter and pre charger, keihn 35mm carbs,barnett racing clutch, gearing is 17,41, cylinders ported for trail, piston windows ported, advanced timing plate +6 degrees, new rings, noss head and 19 cc domes, and vforce2 reeds brand new pedals, just put brand new rings and all gaskets/ seals in it and a new throttle cable.
Read the recent thread about piston windows BEFORE you lay the cash down to do it. JMHO, your results may and will vary !! :cheers:
oh so what now cause i already had it done is this really bad or good or what?
OOPS. From what I've seen it's more common on all out race engine. It depends on the extent of mod and how hard you run it. Can result in craked/broken skirt over time. :cheers:
oh alright well thanks i guess we will see what happens, im ting into drag racing anywhere i can for trophys and stuff ive already won one my first drag race 2cd place against about 30 other people, made a 30yrld guy mad cause im 15 and beat his banshee lol, but a built yfz450 beat me by not even a quad length i was right there on him so i built it a lil more by doing the timing+6* porting cylinders and piston windows, put vforce reeds in, noss head 19cc domes had my crank trued and welded and all gaskets seals replaced and rings and the reed pedals, about a grand in work done over winter, i had jeryy a guy i know pretty well owns his own little buisness and seems to know everything about banshees do all the work on it, it does an awesome job atleast it looks awesome and he always gives me good deals, but it doesnt seem much more powerful with all that stuff done, idk if its cause my front sprocket is so big that you cant tell from that or cause im running premium instead race fuel or what? also about how much hp would it be with all the stuff on it, i was told only 55-60 is this correct i thought it would be more than that
  • 6 months later...
