banshee 268 Posted December 11, 2010 Report Posted December 11, 2010 i have a 421cc with 35mm carbs and im also running fmf gnarly pipes.the problem i see is that the pipe is very close to the to the carb on the left side.so im wondering if anyone has had the same problem Quote
SkinInd_Banshee Posted December 12, 2010 Report Posted December 12, 2010 I would suggest the brand shearer pipe or cpi Quote
06specialedition Posted December 12, 2010 Report Posted December 12, 2010 (edited) I would suggest the brand shearer pipe or cpi Yea both of those pipes are very good, I run CPI's. But if he likes his FMF's and wants a cheap fix, he could put a heat wrap around the stinger tubes. Edited December 12, 2010 by 06specialedition Quote
Larry's Shee Posted December 12, 2010 Report Posted December 12, 2010 Or maybe washers between hanger and frame to space it out some. Quote
banshee 268 Posted December 12, 2010 Author Report Posted December 12, 2010 already did the washer thing and it is still close.not touching but close.im going to get other pipes but not right now.im using this for ice racing and flat track Quote
BigRed350x Posted December 13, 2010 Report Posted December 13, 2010 A few ideas... get some stinger heat shield wrap thingy's from cascadeinnovations. get some header heat wrap from your local auto parts store and wrap the pipes. get some different pipes that fit better around aftermarket parts (like shearer in-frames) Quote
banshee 268 Posted December 13, 2010 Author Report Posted December 13, 2010 k i will do thanks alot Quote
