REmoval:
- Drain coolant and detach tube going into head
- Unbolt head 10 bolts
- Remove old gasket
- Remove 4 bolts holding each cylinder on.
- Slide each cylinder off
- Remove pistons
- Drink a beer
Replace with new parts and gaskets
DRink another Beer
PS - this is assuming you have carbs and intake system off.......
it would be better if there shit worked i get negative results on it you are fucket like me nigaa
question.
"Is there a place that has a step by step process of rebuilding the top end"
your answer's.
"mine ran like shit i will rip it apart agin if it dont 55mph hope this helps"
"it would be better if there shit worked i get negative results on it you are fucket like me nigaa"
i see a bunch of words (some are just a group of letter's), one in front of the other. not anywhere in that basket of words is an answer to anything. :)
nvrstsfd23, as T-shee said, or get a clymers manual. the clymers has step by step with pictures and all.
I started messing with the top end to see what the pistons and cylinders looked like. I made a mistake and forgot to drain the coolant before I lifted the head so when I cracked the head off it leaked coolant out and into my cylinders. Should I do anything to it or will it not really hurt anything.
ARE you doing a topend rebuild? If you are then your gonna need to take the jugs (cylinders) off anyways to get them bored/honed and new pistons. So when you pull those off you'll have access to the crankcase to soak up whatever coolant wound up down there. Shouldn't hurt a thing.......your not the first and you wont be the last to have coolant make its way down there.
Get your hands on a Clymers manual..... you will need it if you wanna enjoy your banshee lol.
contact Jeff @ www.farmandsandtoys.com, he will set you up with one.
