steeler2169 Posted December 7, 2010 Report Posted December 7, 2010 If I don't ride alot I have to kick at least 20 times to start. I do have an air leak from back of carbs to air filter, just ordered pods & outer wear but can't put on till Christmas. Could this be my prob? Jetting I thinks is good 27.5 300 W/ t5,no lid K&N, & vforce. Im probably in wrong area but I get quick response here.Thanks Quote
locogato11283 Posted December 7, 2010 Report Posted December 7, 2010 Have you checked the compression lately? That's the first thing I would do. Your jetting is pretty close. Quote
steeler2169 Posted December 7, 2010 Author Report Posted December 7, 2010 What are good numbers? Quote
locogato11283 Posted December 7, 2010 Report Posted December 7, 2010 Is this an all stock bike or what? Stock porting and head? Quote
Phelps Posted December 7, 2010 Report Posted December 7, 2010 if it just started when it got cold it may just be lean. if it does it no matter the temp you may want to check compression. anything over 120 should start. preferably higher though depending on your elevation. Quote
