YOu have a rod inside there then a ball then that adjuster you have pictured with the end you have arrow on going in touching the ball inside ther.......you adjust using the phillip head bolt inside and the nut is used to lock it.............there are two little arrows on the clutch puller.....on the opposite side of the case......they should line up using this adjuster........you will not be able to pull the clutch once its all assembled......it should be pretty hard
MAke sure u have the ball in there...
