f4istunna Posted November 4, 2010 Report Share Posted November 4, 2010 (edited) Bought this bike early this summer and havent had a chance or much extra $$ to do much with it. It ran when i bought it but low compression on right side. Tore down and found the modquad head have a small chunk missing around a bolt hole where someone put a bigger bolt to replace stripped stud. I planned on redoing the whole bike over winter and reselling next summer but its not gonna happen anytime soon we just had a newborn son and could use the money now so just decided to part this one out. Located near youngstown ohio if local feel free to pickup. I can ship no problem some of the parts are already boxed up and on ebay. Some i still need to find time to clean up and look over good before i list. Prices are plus actual shipping to your zip. If shipping i can accept paypal or money order. I will ship your parts by next business day at the latest after payment clears. -Pro circuit platinum pipes with silencers. Right pipe has half dollar size ding, one of the silencers has a loose or broken inner core you can hear it rattle. Im sure they need repacked. Pipes look good overall. I cleaned them up a little with steel wool but they will come out better with some elbow grease and polish. $150 - Keihin pwk carbs with thumb throttle and cable. I measure them at just under 29mm (28.80) so not sure if just considerd the common 28's or 29mm? Choke knobs work good, no stripped screws. Cable seems good. thumb throttle cover is missing 1 screw $150 - Lonestar extended axle. some surface rust but axle is straight, good splines and threads. Comes with 2 1" spacers, stock locknuts. Measures 39" end to end. $125 - Complete rear brake system. Caliper, stock line, master cylinder lever and resi. Brakes worked, no leaks. Lever could use painted. $90 - Stock ignition coil good spark $20 - Kicker lever and knuckle still seems pretty tight. $20 - Left and right stock spindles. Straight with good threads $35 - Stock rear wheel hubs (pair) $30 good studs and splines, lugnuts included. - Airbox with pro flow and KN Airbox has 1" hole on each side with screen, good lid and clamps. 1 damaged tab on box but mounts solid. K&N filter is well used but has some use left. Pro flow adapter in good shape. Intake boots included. $30 - Aluminum rear grab bar Not sure the brand straight and solid $20 - Front wheel hubs and rotors (pair) Rotors have some minor wear but are straight and useable, good bearings. Could use paint or powdercoated. $25 - Rear brake hub and rotor Rotor straight hub looks good $20 - Stock front shocks 14" red springs, good shape not blown. $70 - Stock radiator no leaks, has a few fins flattend out here and there $15 Thats all ive had time to clean up and get boxed up for now. Hopefully this weekend i can get to the rest. Frame looks good no cracks, needs paint or pc, the pegs are welded on , good engine cases, cylinders need a few studs helicoild i still need to measure bore, trans shifted good. Plastics are pretty rough, wheels and tires im keeping for my other one. good seat, Also have extended a arms not sure what brand . heres a link to some of the pics i have as of now. Will get pics of the rest asap. http://img94.imageshack.us/g/1048603j.jpg/ http://img94.imageshack.us/img94/4615/1048603j.jpg axle http://img843.imageshack.us/img843/4134/1048605.jpg axle http://img220.imageshack.us/img220/5531/1048594.jpg exhaust http://img841.imageshack.us/img841/7192/1048596.jpg exhaust http://img835.imageshack.us/img835/1504/1048568.jpg carbs http://img560.imageshack.us/img560/1281/1048562.jpg carbs http://img295.imageshack.us/img295/8738/1048561.jpg rear brakes http://img840.imageshack.us/img840/7408/1048541.jpg kicker http://img266.imageshack.us/img266/7409/1048623.jpg front shocks http://img826.imageshack.us/img826/2623/1048627.jpg radiator http://img269.imageshack.us/img269/3931/1048632.jpg grab bar http://img198.imageshack.us/img198/9513/1048642.jpg airbox/pro flow Edited November 4, 2010 by f4istunna Quote Link to comment Share on other sites More sharing options...
SkinInd_Banshee Posted November 4, 2010 Report Share Posted November 4, 2010 dibs on the coil i pm`d ya Quote Link to comment Share on other sites More sharing options...
SkinInd_Banshee Posted November 4, 2010 Report Share Posted November 4, 2010 dibs on the hubs! are they 4x115? Quote Link to comment Share on other sites More sharing options...
f4istunna Posted November 4, 2010 Author Report Share Posted November 4, 2010 yep 4x115 rears. Replied to your pm. Quote Link to comment Share on other sites More sharing options...
AKheathen Posted November 5, 2010 Report Share Posted November 5, 2010 what's the deal on the cyls? Quote Link to comment Share on other sites More sharing options...
f4istunna Posted November 5, 2010 Author Report Share Posted November 5, 2010 cylinder bore looks good but will need some studs helicoiled. I havent had a chance to measure the bore size yet. Quote Link to comment Share on other sites More sharing options...
T_Shee Posted November 5, 2010 Report Share Posted November 5, 2010 good seller i have bought from him before Quote Link to comment Share on other sites More sharing options...
AKheathen Posted November 6, 2010 Report Share Posted November 6, 2010 cylinder bore looks good but will need some studs helicoiled. I havent had a chance to measure the bore size yet. well....price? Quote Link to comment Share on other sites More sharing options...
f4istunna Posted November 6, 2010 Author Report Share Posted November 6, 2010 thanks T_shee AKheathen Ill get some pics of them this weekend then you can shoot me an offer if interested. Sound good? Quote Link to comment Share on other sites More sharing options...
mysterion Posted November 8, 2010 Report Share Posted November 8, 2010 PM sent on carbs Quote Link to comment Share on other sites More sharing options...
f4istunna Posted November 8, 2010 Author Report Share Posted November 8, 2010 pm replied Pro circuit pipes are sold AK sorry i didnt get any pics yet ive been feeling like shit the past cpl days w/ a bad cold so havent been out in the garage . Ill get out there and take some pics asap though. Quote Link to comment Share on other sites More sharing options...
bigblockbanshee Posted November 13, 2010 Report Share Posted November 13, 2010 (edited) Pics of radiator to R1Rider31@hotmail.com please. Very interested. EDIT: Sorry I didn't see the link to the pic. Do you have any other more detailed pics? Edited November 13, 2010 by bigblockbanshee Quote Link to comment Share on other sites More sharing options...
bigblockbanshee Posted November 14, 2010 Report Share Posted November 14, 2010 I'm calling dibs on the radiator pending the pix of it, just to get my name in there... Quote Link to comment Share on other sites More sharing options...
Firemann32 Posted November 14, 2010 Report Share Posted November 14, 2010 Would like some more details on the extended a-arms. What about the swingarm, stock or aftermarket? Also are the levers by any chance shorty's? Pics to firemann32@hotmail Quote Link to comment Share on other sites More sharing options...
Trick2stroke Posted November 14, 2010 Report Share Posted November 14, 2010 I'd like to buy the airbox from ya. I'll send you a pm. Quote Link to comment Share on other sites More sharing options...
